Question about Jura Capresso Coffee Makers & Espresso Machines
I HAVE A JURA CAPRESSO ENA 5 AND WHEN I DO THE DESCALE CYCLE IT WILL NOT FINISH THE FINAL DESCALING STEP . IT JUST KEEPS SAYING "DESCALING" AND WILL NOT FINISH. UNPLUGGING DID NOT WORK
Posted by Pat Kampmeier on
4 Related Answers
Anonymous
SOURCE: Describe your Jura Capresso Impressa Z5 Espresso
will start by itself after it was shutoff for after
7-12 hours suddenly ? Why
Posted on Jul 20, 2009
Anonymous
SOURCE: miele steam oven keeps wanting to be descaled after descaling!
Ours does too. Did you ever get it fixed?
Posted on Feb 21, 2010
gaip
SOURCE: Saeco Talea Giro Plus, descaling
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
Posted on Apr 20, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: B80 won't run a full
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
What is error 5 on my impressa j9
Error 5 is pointing to heating problem. Here are the parts that may be malfunctioning:
1- Thermal sensor not registering heating. Replace it.
2- Heater not heating up. Check continuity on heating element. If there is no continuity, (This is rare). Replace heater (Thermo block).
The problem can be linked to:
1- Missed descaling of machine for extended period.
2- Use of automatic descaling method suggested by Jura. Descale the machine every three months using Manual descaling method.. Services Unlimited Inc Parts Guru Since 1988
Jul 03, 2016 | Jura Capresso Impressa Coffee Makers &...
My machine hasn't requested a clean cycle in quite a while. Is there any way to start the clean cycle manually?
At the time of set up, Jura instructions ask activating the use of Filter cartridges. This eliminates reminders for descaling.
Solution:
Throw away the filter cartridges that are expensive, ineffective & block descaling reminders.
Descale the machine every three months using manual descaling method. See link for instructions. Services Unlimited Inc Parts Guru Since 1988
Jun 20, 2016 | Jura Capresso Impressa F9 Espresso Machine
How do I descale my Jura capresso?
all the instruction manuals are on the jura website, capresso.com, you can download the one you need and all instructions are there.
Dec 16, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
I descaled and the machine keeps coming up with descaling on the display window
Did you descale the machine through the actual menu on the Machine? following the steps in the display window? If so, then it sounds like it needs to be sent in for service.
Jan 02, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura impressa x90 keeps beeping
call the 'Coffee Boss"  in North carolina.  you will have to find him on Google. his name is heinz and he is the guy that Jura uses when they can't fix it.  He's fixed my x90 3 times.
good luck
Oct 13, 2008 | Jura Capresso Impressa X90 Espresso...
Coffee Makers & Espresso Machines Logo
129 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
