Question about Harman Kardon Audio Players & Recorders
Repair manual for a Harman Kardon SC 23. - Harman Kardon Audio Players & Recorders
Posted by Mike Lemieux on
5 Related Answers
Anonymous
  • 6966 Answers
SOURCE: Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
naebarbat
Barbat Nae
  • 509 Answers
SOURCE: drivers for harman kardon en toshiba satellite P100
driver for Satellite P100-ST1071 here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1484723&rpn=PSPA0U&modelFilter=P100-ST1071&selCategory=3&selFamily=1073768663#
or try other model for P100-? from >downloads>model
Posted on Jun 05, 2009
Anonymous
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
Anonymous
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
Anonymous
SOURCE: I need the user manual for harman kardon avr 134?
http://www.e-hifi.com.au/downloads/product-files/AVR134%20Eng%20OM_79a3.PDF
Posted on Feb 15, 2011
I lost my remote to my harmon kardon DPR 1001 stereo is their an remote controle app i can download on my phone to controle stereo
No, phones don't have an infra-red transmitter. That would only work if the HK was connected to wifi and HK made an app and the internal circuity and logic to accept it.
Contact HK direct and buy a new remote.
Or
Harman Kardon DPR1001 Remote Control OEM for sale ...
www.ebay.com > ... > Receivers & Amplifiers
+$15.05 shipping. harman/kardon Remote DPR1001 DP1001 - Tested Works ... OEM Harman Kardon HK 3380 Replacement Remote Control For Receiver ... US$54.99 · ‎In stock
Harman Kardon DPR 1001 Digital Receiver ... - Amazon.com
www.amazon.com > Harman-Kardon-Receiver-Disconti...
Buy Harman Kardon DPR 1001 Digital Receiver (Discontinued by ... The receiver comes with Harman Kardon's programmed LCD remote control with EzSet ... I was planning to replace the speakers too, but now I'm having second thoughts!!
Harman Kardon DPR 1001 A/V full digital path receiver with ...
www.crutchfield.com > ... > Home theater receivers
... 1001 Remote. Leave it to Harman Kardon to develop a groundbreaking full digital path receiver. ... Harman Kardon DPR 1001 owner's manual. MFR #DPR ...
Harman kardon avr 510 reset
Page 53 of the manual
Troubleshooting Guide; Processor Reset - Harman Kardon ...
https://www.manualslib.com > ... > Owner's manual
Harman Kardon AVR 510 Manual Online: troubleshooting guide, Processor Reset. Symptom Unit Does Not Function When Main Power Switch Is Pushed ...
I need harman kardon Aura studio service manual
Hello Babak, I sent you the link where you can see online the service manual of Harman Kardon Aura Studio, if you subscribe, paying you can download it directly
Greetings Franco Dosil
Hola Babak, te env?o el link de donde puedes ver en linea el manual de servicio del Harman Kardon Aura Studio, si te suscribes, pagando puedes descargarlo directamente
Saludos Franco Dosil
https://servlib.com/harman-kardon/audio/aura-sm8.html
2answers
How to re-connect the wireless controller
http://www.retrevo.com/pdf/23482ag613/23/Remote+Control#q=Harman+Kardon+GPS-810 try that link you can work your way around and maybe spot the problem. Not sure myself
Top Harman Kardon Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
