The frig door (not the freezer door) came loose today so I removed the plastic guard on top and tightened the door. In the process I accidentally pulled apart a small connector with 2 wires. I snapped it back in place as before. Now I have no light in frig side and no water from the dispenser. The freezer light and ice dispenser are fine. Is there a fuse I might have blown. I did not power off the system at any point.
SOURCE: Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
SOURCE: maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
SOURCE: Kenmore water dispenser not working, side by side frig
no water come out of dispenser to glass
