Question about Smith Corona Office Equipment & Supplies
I found a 1964 smith corona manual typewriter but the keys are stuck like in a lock position. Where is the release?
Posted by Tom Walsh on
Jennifer Gibson
    New Friend:
You could try the shift keys. On mine, I have two blank white keys at the bottom left. When I had a similar problem this helped. You also may have to check for rust, dirt, etc, which can cause keys to lock. It may just need a good cleaning and light greasing of key mechanisms. There are many great websites that show step by step instructions on cleaning and maintenance. Hope this helps.
Posted on Feb 09, 2018
5 Related Answers
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Posted on Oct 29, 2007
JUSTOLDJIM
James Cagle
  • 482 Answers
SOURCE: smith corona typewriter settings
I am not sure but I think you the code key while pressing the format key then make the selection in the display.
Posted on Aug 21, 2008
Anonymous
  • 45 Answers
SOURCE: Need owners manual:
I have been unable to find a site where you can download a Smith Corona typewriter manual. However, you can try going to Will Repair Service. They carry manuals of every Smith Corona typewriter ever made, and you should be able to find a manual for your particular typewriter there. I find them to be a very helpful and trustworthy typewriter shop.
YES, SMITH CORONA DOES STILL EXIST!
Best of luck to you! :-)
Posted on Jun 07, 2009
agent91
Ned White
  • 2100 Answers
SOURCE: 1903 Springfield Parts List Service Manual
Go to gunparts.com for a complete schematic of every rifle made, and parts, including your 03A1, A3,
Posted on Mar 04, 2010
christyrse
Christy Fredericks
  • 45 Answers
SOURCE: Where can I download free an owners manual for
Go to this link  https://www.smithcorona.com/manuals.php
and you will have to go to each Chapter, and download it...under the Office 2000 Memory Typewriter or the Display Typewriter.
Good Luck!
Posted on Oct 18, 2010
I need Smith-corona sterling manual
PDF]SMITH - CORONA STERLING
site.xavier.edu/polt/typewriters/SCSterlingManual1963.pdf
Your new Smith-COrona Sterling is a precision built writing ... ponents or when youhave occasion to change ... ble quick and easy it you follow instructions.
[PDF]Owner's Manual for Smith-Corona Standard Portables
sevenels.net/typewriters/manuals/Smith-CoronaPortablesManual.pdf
YOUR NEW SMITH-CORONA PORTABLE is the finest portable typewriter ... havemade Smith-Corona portable typewriters the ?rst Chain: of millions.
Smiths & Coronas - Sevenels.net
sevenels.net/typewriters/s-coronas.htm
See here for a quick-reference guide to Smith-Corona portable serial number prefixes. ... Download the manual for this typewriter here. Corona Four Serial # ... So why haveonly a fraction of these already rare sterling silver Sterlings survived?
Smith-Corona Sterling Manual Typewriter - YouTube
? 0:41
https://www.youtube.com/watch?v=gt9MsZWWHiE
Feb 04, 2016 | Smith Corona Office Equipment & Supplies
How do I fix my Smith Corona SC110 Typewriter?
make sure the right hand platen knob is tight hold the platen and turn the knob top toward the back of the typewriter until it is tight
Aug 17, 2014 | Smith Corona Wordsmith 100 Typewriter
Smith corona SL480 instruction manual. I just need a manual so I know how to use the features built into the typewriter
How to Use a Smith Corona Typewriter A Smith Corona typewriter can be either a manual or electric model. Whichever model you have, the typewriter works in basically the same way. If you are familiar with a computer keyboard, you can type on a typewriter as the keys are laid out exactly the same. Unlike a computer, typing mistakes are harder to correct and, unless you use carbon paper, you will only have one copy of any document you type.
Aug 03, 2010 | Smith Corona Office Equipment & Supplies
SMITH CORONA KA 13 WORD SMITH
For a manual, try Google. Just put in "Smith Corona KA 13 WORD SMITH MANUAL'. If you can't find one there, then you are prabably out of luck. To change the margin simply go to the left margin, use the "backspace" or spacebar to position the print head where you want the margin set and then push the L MAR key. To change the right margin use the same procedure and hit the R MAR key.
Oct 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Smith corona xe6100 keys locked
there is a KB ON/KB OFF switch on the right side of the keyboard, it should be in the ON position
also on the left side the switch should be in the TYPE position
if that doesn't make it work, there is a problem with the main board or power supply that will need a visit to a repair shop
Oct 01, 2008 | Smith Corona Wordsmith 200 Typewriter
My keys have locked. How do you unlock them?
If any of the keys are stuck in the down position, it will lock out the entire keyboard so that none of the keys will work.
One think you can try, is turn the typewriter upside down, and hit the bottom of the unit (right above the keyboard). See if there anything that falls out besided dust. Also hit ALL of the keys. Each and every one of them just to make sure non of them are stuck down.
Try this a couple of times, and see if it helps any.
Good luck.
Feb 06, 2008 | Smith Corona Wordsmith 200 Typewriter
78 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
