Question about Turbo Air Refrigerators
M3 turbo air refrigerator - Turbo Air Refrigerators
Posted by Billy bonds on
M3 turbo air freezer. M3F24-1 temp on display is not temp of box
this could be a bad temp sensor or lack of proper air flow. Make sure the evap fan runs when it's supposed to be running. Also make sure the evap is not freezing up. all these items can cause what you are describing.
Aug 06, 2016 | Turbo Air Refrigerators
Can you replace the door sliders on the tst-28sd-d2 one of the guides broke
You should be able to find the part at this website. They have a full line of Turbo Air parts for commercial refrigerators.
https://www.kitchenstuff.com/turbo-air-greenworld.html
Sep 13, 2015 | Turbo Air TST-28SD-D2 Super Deluxe...
Why it make loud sound like fan is thatching some metal when i plug in?
check the fan blade to make sure it is tight on shaft. also check to see if any of the fins are bent could be that they are hitting the housing of the fan motor.
Jun 07, 2014 | Turbo Air MUF-48 M3 Series 2 Door 48"...
Door lock for Turbo AIR
How to remove the 3 locks from the panel. Both side of the panel are riveted. How to remove the panel to reach the 3 locks.
Jul 21, 2013 | Turbo Air Reach-In Refrigerator- 3...
Who makes the thermostat for model #msr49nm
Isn't 37 ok? Check the condenser is clear and clean before replacing thermostat
Apr 24, 2012 | Turbo Air MSR-49NM Refrigerator Commercial
M3 Turboair Refrigerator does not cool
http://www.turboairinc.com/TB-Service/Service.html#SANDWICH
Try this web site. It has you M3 listed with manual but needs exacting model number to get right one.
good Luck - Hope this works for you. If not, let me know.
Jun 27, 2009 | Freezers
Self closing doors don't self close any more
This problem can be corrected by adjusting the hinges.
May 09, 2009 | Turbo Air MSR-49NM Refrigerator Commercial
Refrigerators Logo
82 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
Lawrence Oravetz
john h
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
