Question about Turbo Air Refrigerators
SOURCE: refrigerator 52 degrees
Hi Mike,
I am having the same problem with a Hotpoint side by side. (Model # hss22ifmd ww ) Could you tell me the more detailed info mentioned above. Thank you so much.
chris
Posted on Jan 02, 2008
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
SOURCE: Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Posted on Nov 29, 2008
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
SOURCE: gshs5kgx refrigerator not cold enough, controls
Did you solve this problem? We're having the same problem on our GE same model, but no turbo cool option.
Posted on Feb 24, 2010
Aug 06, 2016 | Turbo Air Refrigerators
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
Jan 04, 2011 | Frigidaire FRS26R4A Side by Side...
Apr 17, 2017 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Jan 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jun 28, 2009 | GE Profile PFS22MS Bottom Freezer French...
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jun 02, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
272 people viewed this question
