SOURCE: Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
SOURCE: Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
hope u find this useful. thank you.
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
SOURCE: Thermador over/microwave/heating drawer model SMW272YP Bake
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
