Question about Sharp Refrigerators
I have a Sharp SJ-48H fridge that opens left. I want to reverse the door opening but the lower door bottom hinge is not reversible. Where can I get p/n SJ-R815?? Which I think is what I need?
Posted by pilotpearson on
Steve P
  • Sharp Master
  • 3,712 Answers
Hey Pilotpearson,
try here..
Sharp Refrigerator Parts
Hey Yours may be too new to have been listed yet.. give them a call...
Posted on Jun 24, 2017
Testimonial: "The Sharp model I have wasn't listed on the site"
I have a Samsung refrigerator RL46WBSW. How can I reverse the direction of the door opening from left-right to right-left?
Most fridges are designed so that the door can be flipped to reverse the opening direction. Look where the hinges are now. Look on the other side of the opening. Are there mounting holes to accept the hinge bolts? If so, unbolt the door, flip it so the bottom is now the top, and re-attach the hinges and bolts.
If you lack mounting holes, the door likely cannot be flipped.
Mar 17, 2018 | Samsung Refrigerators
I have a grundig fridge freezer and would like to reverse the doors to open right hand way, can it be done if do how much, and do you have a specialist who can do this.
All you do is unscrew the top hinge from the fridge whilst supporting the door. Lift off the door. Unscrew the bottom hinge and put it on the other side. Fix the hinge then support the door on the lower hinge and screw in the top hinge. Check the allignment and adjust as needed.
Jun 09, 2017 | Refrigerators
Door slams open Maytag Fridge MZD2766
Human error may have resulted in the hinges being installed incorrectly. To confirm your suspicion, check a similar Maytag on display in a store.
May 26, 2017 | Maytag MFD2561HE Bottom Freezer French...
The doors open in the wrong direction
remove top screw for freezer door remove door then remove next hinge then remove fridge door reverse hinges when putting back on reverse handles to other side
Mar 01, 2014 | Thetford NORCOLD N641R - Norcold Finished...
How do i fit the door on the other side
If you look at the opposite side of your refrigerator, you'll find one or more plastic covers which can be removed to expose mounting holes. You have to remove the doors from the current mounting position, remove the hinges and transfer them to the other side, install the doors and you're done
Jan 25, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
I just got a used GE Profile Refridge and would like to change the door from left opening to right side opening. How would I do that?
Hi. Look carefully at the door and check to see that there are buttons on the side of the door opposite of the hinge. Those buttons conceal the alternate set of screw holes for the hinges. If there are no predrilled holes on the other side of the door then it is not reversible.
That said, If you do locate those buttons, unscrew the hinges from the door, have a helper there as the door will be heavy. Once the door is off, remove the hinges, then move them to the opposite side and reattach the door to the fridge. Put those buttons in the new open holes. J.
Jul 30, 2010 | GE Profile Stainless Bottom-Freezer...
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
We have a fridge/freezer, upright bought some 15 years ago. Works fine, but we wish to reverse the doors to right opening from left. Please advise how to do it.
if you can notice that the doors have plastic plugs to the other side of the hinge then it is design to be reversible.
but if there is no indication that you can transfer the hinge to the other side of the door, then it is not designed to be reversible and there is nothing you can do about it.
i'm not sure if the old fridge are designed to be reversible.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Refrigerators
Refrigerators Logo
128 people viewed this question
Top Sharp Refrigerators Experts
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
