Question about Manitowoc Kitchen Appliances - Others
I have a manitowoc model sd0502a that doesn't produce ice or when it does it takes an hour from start to finish
Posted by jesse m weaver on
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Ice maker
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Posted on Oct 29, 2008
Joe Palazola
  • 124 Answers
SOURCE: i have a model qd0452a manitowoc and it will not
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Posted on Dec 11, 2010
Joe Palazola
  • 124 Answers
SOURCE: manitowoc ice maker does not produce ice
If it doesn't run at all open the front panel and peer inside of the control box. See if there are any indicator lights on the control board lit or blinking. Check the plastic water curtain on the machine and make sure that the magnet is in place on the bottom right. Will need more information as to what lights are lit. Printed on the board next to each light is its corresponding function or response.
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: Manitowoc Ice Maching. Model B400.
that is a 400 lb. per 24 hours machine. can you explain the problem in further detail.
Posted on Sep 18, 2011
shingadia
  • 9 Answers
SOURCE: have manitowoc ice machine model
CK TROUGH LEVEL SENSOR! THE PROBE OR SOLENOID ARE DEFECTIVE. LEFT BIN LIGHT ON GRN+ PROBE LIGHT OFF RED. TO PROVE WATCH FOR 3 MINS TROUGH WILL OVERFLOW INTO BIN >DRAIN.
Posted on Sep 02, 2012
My Manitowoc Ice machine will not produce ice. The harvest light is on and it will run through the clean cycle
Hi, contact your local appliance repair facility, you may have problems with the control board, the ice level sensors or curtain.
Nov 26, 2017 | Manitowoc Kitchen Appliances - Others
Doesnt make ice
Check compressor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jerry_8a145f1328fa119f
Sep 05, 2014 | Manitowoc SD0502A SSeries Ice Maker Up To...
Why does harvest light stay on
Machine dirty
Jun 13, 2014 | Manitowoc SD0502A SSeries Ice Maker Up To...
Manitowoc troubleshooting
Clean the condenser thoroughly, descale and sanitise the waterways inside.
Feb 15, 2014 | Manitowoc Ice SM-50A Undercounter Ice...
Manitowoc sd0502a has power but no water coming in
#1 check if the water level light is illuminated on the board.If illuminated and there is no water in the trough, replace the water probe.
#2 Check for water pressure into the machine( turn off power and water. Disconnect the water line from your machine and put line into a bucket and turn on water supply pressure and flow.) If you have water in the bucket then you have either no voltage to the valve or the valve is bad. If you can use a meter and know your machine voltage you can check the valve this way. Another way is to turn the machine on and listen for the valve to click after a couple of minutes. These valves can be disassembled and cleaned if plugged up. I use a pointy tool to clear the orifice in the valve.
Feb 14, 2012 | Manitowoc SD0502AB570 S Series Ice Maker...
Manitowoc Ice Maching. Model B400. Water comes out instead of ice.
Sep 18, 2011 | Manitowoc Heating & Cooling
I have a Manitowoc QD0212A 120v. It makes ice, but after the bin gets full, it appears that the compressor does not run to cool the ice box. Is there some type of relay or solenoid that could be bad?
Try cleaning the radiator for the ice box compressor it could be tripping it's thermal overload switch, if that doesn't work check to see if the termostat setting is in the range for the compressor to turn on when the ice starts melting.
Jun 29, 2011 | Manitowoc - QD-0212A/115-1
Kitchen Appliances - Others Logo
161 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
Marvin
Marvin
Dennis
john h
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
