Question about Chime Home
Put new movement in grandfather clock. its keeping time but wont chime
Posted by Effie Burton on
spencer hughey
    Problem Solver:
  • 16 Answers
You probably already checked this, but look at the chime silencer switch, usually just a little shitch on the face near the 9 o'clock position.
Posted on Jun 26, 2017
5 Related Answers
jdthefixer
  • 747 Answers
SOURCE: Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Posted on Mar 29, 2009
John McCaffrey
SOURCE: Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
Posted on Jul 03, 2009
Anonymous
SOURCE: Shontek clock movement from Sam's club not keeping time
Were you able to repair your clock ? I have the same 24" clock from Sam's Club and have given up on finding the Shontek DM2720 movement. Please let me know.
Posted on Aug 03, 2010
Anonymous
SOURCE: Have a Galleria Grandfather clock thats chimes are
try movinging the hour hand to the time the chimes are chimeing at
Posted on Sep 07, 2010
Anonymous
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Posted on Nov 10, 2010
Metamec spring driven pendelem clock won't chime how can I resolve this problem
Mine won't chime any more and a repair man tells me a part has worn out and needs replacing. Over time they all wear out.
Jun 12, 2017 | Chime Home
It wont chime on the hour
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Apr 19, 2016 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
Gazo Rancho Santa Fe Grandfather Clock won't chim
Check the wires in the back.some times the get corrodes.
Dec 17, 2014 | Home
Halo Grandfather Clock won't chime hour
In my eyes there are two kinds, ones that are a real grandfather clock that runs on gravity using a series of weights and gears with different counterweights for chimes and running the clock itself, and there are the show pieces that look like a grandfather clock but run on newer tech and electronics. If a real one then would try first pulling the weights to the top. They are usually shaped into a pinecone or something. If weight is at bottom them have to pull corresponding chain with weight till the weight is at the top of case. As "time" goes by the weights lower. You should have different counterweights for the clock, chimes, dancing figures and whatever else it may have. All the weights move at different "speeds" so you have to keep an eye on them to make sure it keeps correct time. I would recommend consulting the manufacturer if possible. There are so many kinds out there is really hard to tell by such a short video.
Dec 16, 2014 | Home
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
Need setting instructions for clock movement
Howard Miller offers this feature: This is how it works.
Automatic Night-Time Silencing Option
Grandfather Clocks will offer a night time shutoff option. There are 3 options on this lever.
1) "Night On" - This will keep the chime striking 24 hours
2) "Night Off" - This position will turn off the chiming between 10:15PM and 7:00AM
3) "Strike" - This position will allow the movement to strike the hour without the Westminster melody if the other Westminster melody lever is turned to Silent.
Hope this helps.
R/David
Apr 05, 2009 | Oregon Scientific Lwb0997110113004...
Mar 29, 2009 | Elgin 0518709FA
Home Logo
3,518 people viewed this question
Top Chime Home Experts
Marvin
Marvin
Vernon Taylor
Fahr Quad
Are you a Chime Home Expert? Answer questions, earn points and help others
