That error indicates a temperature problem in the fixing unit. You need to enter in service mode and clear the error . If problem persist you need to replace the fixing heater
yep that would be right
with a new hard drive , the bios will not boot up unless there is an installed operating system which a new hard drive will not have
What you may have to do is to get to the bios screen change the boot up to external or cd set and save that
connect the external cd / usb stick with the program installed then start up the computer as normal . it will boot from that system
Hi. That error is related to the fixing unit. You need to clear it from service mode first.
You need to be quick doing the next process because machine will automatically turn off after a few minutes.
With the copier turned on press the next key secuence Press adittional function Press 2 and 8 ( at the same time ) Press additional function. Service mode should appear in the screen . If it doesn't repeat the secuence until it does . When service mode appears press in the touch panel COPIER Then select FUNCTION Then select CLEAR then select in the lower list ERR Then press ok in the lower corner Turn off the machine from main Switch. Wait a few seconds and turn it on again . Try to make some copies . If error persist there is a malfunction in the fixing heater and need to be replaced.
No.
I believe this error is a fault in the heating of the fuser unit.
Could be a blown heater element, or a fault in the temperature regulation control circuits.
You will probably need a qualified technician to fix this.
