Televison & Video Logo
D
David Burroughs Posted on Jun 22, 2017
Autoscan w/ TV set at Air shows 68 RF CH and Found-2 Why am I receiving only 2 channels?
I bought an OTA antennae. It is just a flat pad w/ a wire that connects to the TV. I attached the pad to a nearby window as suggested. When I ran autoscan w/ Tv set at Air the result was RF CH -68 and 2 found. So I'm getting 2 channels. Anyone know how I capture more of the 68 RF CH
2answers
I have a element tv and I can't get any channels programmed in but ch.3. It is hooked up to suddenlink box.i have tried autoscan and nothing
The suddenlink box transmits on channel 3 and is the only signal being transmitted. When the TV looks for all channels it will only see the one coming into it. This is normal because it is assumed you are controlling channels with the sudden link box, not the TV. If you are using an antennae then you need to go into the TV's setup menu and change the settings from cable to antennae.
HOW DO I REPROGRAM PANASONIC TC-22LH30. BOUGHT IT USED AND WORKED GREAT ON CABLE. I WANT TO PROGRAM IT ON ANTENNA,
First... You need your working Remote
  • Input
    • TV
  • Now, Menu
  • Scroll to Program
  • Locate and choose from list "Antenna or Broadcast TV or Air or OTA". Different models vary
  • Then choose Scan for channels.
It's important that your antenna is hooked up correctly, and able to catch frequencies. Otherwise NO channels will be found.
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Dish tv support
Hi Vicki,
You may call them at
  • CALL US 1-888-615-3725 for DISH
  • You can also try this steps:
  • MISSING OVER THE AIR CHANNELS The quality of reception and number of channels available depends on the antenna's placement and the customers location. Weather conditions may interfere with channel reception. The Channel Display receiver menu option may not be set correctly.
    1. Check Over-the-Air Antenna ConfigurationCheck that the wiring between your DISH receiver and your over-the-air antenna is configured properly using Setup OTA
    2. Reset ReceiverIf the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
      Please note: It may take up to 5 minutes for the reset process to be completed.
    3. Rescan Over-the-Air Channels to ReceiverAccess "Local Channels" select "Scan Locals" then "Save".
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
4helpful
2answers
What is RF CH used for?
RF is used for Radio Frequency on your Qam tuner to break it down its the tuner like cheel 1-99 or 1-125 or digital RF clear Qam tuner so RF is your tuner respectivly. You would use this when you have a OTA over the air antenna or sraight cable meaning from wall outlet to tuner not wall outlet to cablebox.
I hope this clears up the meaning.
Thanks for using fixya.com I hope this was Very Helpful to you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Olevia tv erased all channels accidently
BEVERLYQC::
How do you " accidently erased all my chanels " from a tv??
Was the TV connected to a 'cable box' ?
Was the TV conected to 'air waves' or antena input.?
If the TV is attacned to a cable box, temperly remove the cable box INPUT wire, attache an antenna to the IMPUT AND AUTOSCAN WITH THE REMOTE CONTROL
If the TV cannot 'autoscan' in 'air wave' reception...goto menu and set input channel to ch.3 or see if there is a switch in the back that can change to ch.3 or ch.4
You should get all the 'air wave' chanels which will include ch.3 & ch.4
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
