SOURCE: Changed ink cartridge, now printing with green hue
most of the time this happened to me, I noticed I knocked one of the ones next to it slightly loose. Just check and make sure they are all seated fully.
SOURCE: flashing E, says print cartridge is not compatible with printer, wont turn off unless unpugged.
Try reseating the cartridge first.
Eliminate the possibility of a bad cartridge, try another one.
SOURCE: error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
SOURCE: Kodak 5100 AIO won't print after cartridge change
the red blinking light indicates that your printer wont recognize your ink carthridge. you can try to reseat the carthridge and the printhead. to remove the printhead just press on the release tab which is located on the upper left corner of the printhead wall. If this will not correct the issue, you need to call their technical support hotline. maybe the carthridge is faulty or there is a problem on the printhead. their hotline no is 1 800 421 6699
