My Samsung SCX-4521F does not want to feed the paper properly. The feeder rod only turns one`s or two times but the paper are not going through and then the paper still feel loose?
Sanjay,
I think you should take all unused papers out, close tray and predd print button. If there is paper in the system, it may come out. A red light may also flash asking you to load papers. Now lod the papers and the red light will go off. Put a printed paper and try copying. If it copies, you are ok. Now print from your cpmputer command. If it prints you are ok. If it does not and you get paper jam warning, there may be a small piece of paper stuck in the system. You have to open each feeder and see if you find anything. Good luck.
Your printer has been "stacked", open your printers paper driver and see if its clean, maybe a paper is blocking the paper feeder or the printers drum.
regular fax job plus PC fax
The SAMSUNG SCX-4521F is an
efficient fax. It also has the ability to send a fax document directly
from your PC via the supplied SmarThru 4 software.
Save time and paper by simply clicking on the ''PC Fax'' button from your computer.
Hello there, If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer. Close the front cover. Press the power button to turn the printer back on. Resend your document to print.
Ensure that: The paper is a recommended paper for Laser printers. You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder. The printer is on a flat, level surface. The left paper guide is against the side of the paper. You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper. The left paper guide does not cause the paper to bend in the sheet feeder. Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes. Envelopes or the appropriate specialty papers are selected in the printer driver. You are using a paper or envelope size supported by your printer. do not forget to rate this solution....good luck
