The Avery L115 has a dot matrix printer that does not work, and I do not know what might be the cause of the failure. Can anyone help to solve the problem. Is there any test in terminal configuration to check printer?
SOURCE: DOT MATRIX PRINTER PROBLEM
Hi, to perform a self-test on an Epson LX300 > start with the power switch off. Press LF/FF (middle switch), without releasing that button, power on the printer. If everything is ok it will print a sel-test page. To do a Hex Dump > start at power off, simultaneously press Font and the LF/FF buttons (left & middle buttons), then power on; to revert the printer to its factory default setting(s) > start in off position, press Font (left) button then power on. (Slightly different with an LX300+) Hope this works out for you. Cheers.
SOURCE: Lexmark 4227 Plus Matrix Printer on Vista
Operating System Printer Driver Installation Procedure
NOTE: This procedure involves driver installation and port creation using Microsoft's Standard TCP/IP printing.
Step
Action
Click on Image
Click on the Microsoft logo start button.
Click on Control Panel.
Click on Hardware and Sound. NOTE: Classic Mode users can double-click directly on the printer icon.
Select Add a printer.
Click for Image
5
Network installation
Select Add a network, wireless or Bluetooth printer (for direct IP printing, network print queues - \computernameprintername, etc.)
NOTE: For printers connected via LPT1 (parallel), select Add a Local printer (e.g. IEEE- 1284 compliant printer cable, etc.)
6
Observe Searching for available printers...
Upon completion, select (highlight) your printer, and click Next.
Your printer's IP address will be displayed under the printer description. Use the IP address obtained under Recommended above.
Available Windows Vista Search options:
HINT: Windows Vistawill only search the local subnet. If you are confident that theprinter is communicating over the network, select The printer that I want is not listed and try to add the printer's IP address manually.
7
Observe Detecting the TCP/IP Port...
NOTE: Windows will automatically move to the next page when the detection is finished.
8
Observe Detecting the driver model...
9
The Printer name will appear, click Next.
Optional: If youwould like a distinctive printer name and do not want this printer tobe your default (i.e. main) printer, enter a different printer name and deselect Set as the default printer.
10
Observe Installing printer...
11
Upon completion, a Windows test page will print. You can verify the printer's installation by opening the printer's window.
SOURCE: PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
SOURCE: PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
SOURCE: epson lx 300 dot matrix printer not printing properly
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
