SOURCE: cannon ir 1023 will not scan in windows 7 64bit
For the scanning you have to use the USB port and load the Tool Box 4.9 scanning software on the CD or from the Canon site. If you have commercial scanning software you will have to use the Scan Gear software as an interface between the scanning software and the copier.. Good Luck.
SOURCE: solution to errorE000003 0f ir 2520
Press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
SOURCE: After installation of canon IR 2520 its give me an E000716
communication error between the added cassette pedistal. check all the connectors. make sure you have programmed the correct size for this unit in additional functions ,make sure of a a4 or ltr selection where ever your at in this world.
