The teeth on all gears are perfect. Did i not mesh the gears correctly upon reassembly? did i possibly knock something loose? help!
Sounds like you haven't put some of the parts back properly , take off the cover again and make sure the drive shaft can turn freely and check the parts are seated in the correct place , ps make sure you use the correct grease for the moving parts and gears good luck colin
Sorry, what is the drive shaft? is it the long rod-like part next to the worm gear assembly? Also: the grease came w. the mixer so I assume it is the correct kind. Thanks!
A instruction manuel won't tell you to open the case where there's electrical pats exposed unless your a qualified electrician but you said the grease came with this, where does it go
The grease goes around the gears within the mixer. here is a photo of the top coverhttps://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwipgZjmxs3UAhWM5CYKHYZfCv4QjRwIBw&url=https%3A%2F%2Fwww.flickr.com%2Fphotos%2Fphotophiend%2F4253337610&psig=AFQjCNHnkstjecdaHeGUxJfhSuiqaapmkg&ust=1498086889482519
bottom coverhttps://www.google.com/url?sa=i&rct=j&q=...
