Question about Smeg Kitchen Ranges
I have a smeg stove,one of the burners does not light up automaticaly what can i do ?
Posted by gerard fortry on
I have a new Smeg stove and can't get the gas oven going.
The stove should have a safety valve that needs to be removed upon first use , remove that then open the gas and then iginite pilot flame.
Jun 08, 2018 | Smeg Ovens
Smeg 90cm burner tha lights up and goes off as soon as you let go the knob
For the oven burning cakes check the oven tempeture sensor for the top burner issue would check the igniter harness and the the igniter modules on the harness as well sometimes called spark igniters or infinite switches
Mar 07, 2015 | Smeg Ovens
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
Nothing happens with the ignition, no spark at all. I now have to light hob with a match
heatman101
Sep 16, 2010 | Smeg S300X Electric Single Oven
Ignighter is not working on any burners
if if does not light anymore you have a ignition sequence fault could be a faulty switch foe the ignition pcb ht lead or electrodes
Aug 21, 2009 | Smeg HB96CSS Gas Cooktop
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool electric range burner exploded ''on'' light on always
Hi There,
While the stove is unplugged remove the bad burner from the stove and set the bad burner's control knob to the "OFF" position. Now plug the stove back in. If there is a problem it should trigger the breaker and shut off the stove. If you are not comfortable doing this you might want to ask someone.
The explosion was due to a shorted burner element and once it is removed there shouldn't be any more problems. I hope this was helpful and I hope you get your stove going again.
Mar 26, 2009 | Kitchen Ranges
Kitchen Ranges Logo
133 people viewed this question
Top Smeg Kitchen Ranges Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
