Question about AT&T Cell Phones
Life wireless apn settings for at&t kyocera duraforce e6560
Using Life wireless sim card with at&t unlocked kyocera duraforce e6560. No access to internet with data network, a wireless netwwork connection wiil access internet. Is there an apn setting that enables internet access thru Life Wireless mobile data netwoork?
Posted by Frederick Dulay on
honeybun1986
    Master:
  • 329 Answers
The best place to get these settings is from your service provider. Call up on their customer care hotline and ask. They'll send an SMS containing the settings.
Posted on Jun 20, 2017
5 Related Answers
jmassengill
Johnny Massengill
  • 345 Answers
SOURCE: Wireless Connection Good but PC Often Can't Access Internet Sites
I would scan the computer for viruses.
Posted on Nov 09, 2008
Anonymous
  • 520 Answers
SOURCE: wireless network problem
go into ur wireless network properties.click internet protocol.check settings .if obtain ip auto is checked.connect to the unsecured network to obtain details..ip,gateway , dns etc.
disconnect go back to wireless properties and select use the following ip/dns in internet protocol and type in the details..this will get u connected..once connected left click on connected icon in sys tray and select repair this should make changes to ip and dns..it may change it may not ..if not it doesnt need to.
Posted on Jan 14, 2009
Anonymous
  • 111 Answers
SOURCE: Setting up a computer as a wireless internet router
for windows xp you man set up the connection via cable or bluetooth and ms active sync - the htc (windows mobile) is able to use the hosts network connection.
you may also set up an ad-hoc wlan on you eee and turn on internet connection sharing for your mobile broadband connection. if you connect your eee to the ad-hoc wlan it should be able to access the internet
Posted on Mar 20, 2009
hamster47
  • 739 Answers
SOURCE: I have a BT 2-wire hub with networked printer.
First thing, Does your printer have a wireless facility built in? If not it has to be connected to the hub with ethernet.
Normally setting up a wireless printer involves using cables until the set-up is complete. It's nothing to do with the router but all to do with the printer.
Best thing is to go through the manual.
Posted on Oct 14, 2009
Glenn
  • 179 Answers
SOURCE: I have a 5 month
Seems like your phone is functioning correctly.
You have disabled wi-fi so it is asking whether you wish to use Phone Data Connection instead. (Standard Practice when trying to access data services)
What you need to do is un-tick the option in options Use only 2g networks. (3g is the mobile data service) That should then allow you to access Mobile Data. (3g)
Also enable data enabled
Posted on Jun 17, 2011
Life wireless apn settings for at&t huawei ascend xt2 H1711
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type:<Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings >Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547 Network APN Kyocera DuraForce XD
Oct 03, 2018 | AT&T Cell Phones
I have an unlocked LG gpad 7.0 4g lte with a LIFE mobile sim card (free lifeline service). The device recognizes my sim but there is no mobile data connection. The apn settings are blank. I'm in...
You only get mobile data if you pay for a telephone plan with data. It sounds like you have a basic lifeline service with no data. You can only use yours on wifi.
The reviews on Life Mobile are not good and according to the link they have been bought out and are now Plusnet Mobile unless that is only in the UK.
LIFE Mobile reviews ' S21
www.s21.com/lifemobile.htm
I joined life mobile in August 2015, transferring my previous number to the new network. Since then I haven't been able to receive all texts and calls from a variety of people. has been 5 MONTHS and the company hasn't been able to find a solution. I have to try out a number of replacement sim cards and have had to give ...
LIFE Mobile reviews ' S21 ' questions
www.s21.com/lifemobile.htm?question=1 Just so you know, we're no longer LIFE Mobile, but plusnet Mobile, and we're a mobile network ourselves. Our SIM cards require your handset to be GSM compatible, which the great majority of handsets are. So if you have normal mobile telephone services currently, you should expect the same with one of our SIMs. :)
Plusnet Mobile: 5 things you need to know - uSwitch.com
https://www.uswitch.com > Features Dec 6, 2016 - SIM card. Plusnet Mobile is all about keeping things simple. That means it won't be selling phones, rather it will be a SIM only network offering rolling 30-day contracts only. If you've got ... Life mobile. Plusnet Mobile is a result of a tie-up with SIM-only provider LIFE Mobile, which was bought by EE in 2014.
LIFE mobile sim card Google Search
Feb 14, 2018 | LG Cell Phones
I have a zte z832 unlocked cricket phone and I put my life wireless SIM card from the lifeline free phones in the phone and need to set the APN ..does anyone know the APN to set to this phone?
  • type it in exactly as it appears below.
  • APN: wholesale
  • APN type: default,mm,supl
  • Proxy: not set
  • Port: not set
  • Username: not set
  • Password: not set
  • Server: not set
  • MMSC: http://wholesale.
    mmsmvno.com
    /mms/wapenc
  • MMS Proxy: not set
  • MMC: 310
  • MNC: 260
  • Authentication type: not set
  • APN Protocol: IPv4
  • APN enable/disable: APN enabled
  • Bearer: unspecified
  • MVNO type: none
  • MVNO value: not set
Press the Menu key and save. Reboot your phone and test your data connection by opening a web page.
Oct 20, 2017 | ZTE Cell Phones
Life wireless APN setup - Cell Phones
From the Home screen: Swipe right-to-left across the screen to open the Apps list. Scroll down and tap Settings. In the Settings menu, tap Network & wireless. Tap Mobile & SIM. Scroll down and tap SIM settings. At the bottom of this page, you will find separate buttons to add the Internet and MMS APNs.
May 16, 2017 | Cell Phones
I have a at&t htc 610 that's with life wireless now and I need the apn settings to send and receive mms and surf the Web . Can anyone help please?? Asap!!
Go to Settings>Mobile data>Access point names then press Menu and select New APN. Then enter these settings:
APN: tslpaymnet
Proxy: 'Leave blank'
Port: 'Leave Blank'
Username: 'Leave Blank'
Password: 'Leave Blank'
Server: 'Leave Blank'
MMSC: http://mms/
MMS Proxy: 193.35.133.194
MMS Port: 8080
MMS Protocol: 'Leave Blank'
MCC: 234
MNC: 33
Authentication type: PAP
APN Type: internet+mms
Jan 19, 2016 | HTC Cell Phones
How do i find a user manual for my smart phone
PDF]KYOCERA DuraForce User Guide
https://www.kyoceramobile.com/duraforce/DuraForce_User_Guide_ATT...
KYOCERA DuraForce. User Guide ... Charge the Battery Wirelessly .......... ........................................................................... 5. Turn Your Phone On and Off .
Nov 05, 2015 | Kyocera Cell Phones
What is the unlocking code for a Kyocera Hydro Life..model #6035?
Resetting the phone If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a reset.
There are two types of resets-soft resets and hard resets. In a soft reset,
all records and entries are saved. In a hard reset, all records and entries
are erased. If you must do a hard reset, you can restore any data that you
previously synchronized using a HotSync operation.
To perform a soft reset
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
Feb 02, 2015 | Kyocera Cell Phones
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
Unlock net10
I've never used a BB storm 9530, but if phone/sms is working but data is not you do not have the APN settings for Net10. The correct APN Settings are here: http://apn-settings.com/net10-apn-settings-easy-setup-guide/
Nov 03, 2017 | RIM BlackBerry Storm 9530 Smartphone
Cell Phones Logo
1,283 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
