I am trying to fix a friend's TV after a lightning strike hit her apartment and killed all electronics on one wall of her apartment - including a coffee maker, toaster, and the TV. The TV is a Vizio D50-D1 and will no longer power on since the storm. I have done some research and have found available Power and Main boards for the TV as replacements. Does anyone know if its a possibility that the strike fried anything in the TV (like the screen maybe?) that would make it basically unfixable? I have the back off the TV and nothing looks burnt or wrong. Thanks for your help! - Mason
SOURCE: Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
SOURCE: Sceptre power supply short circuit
I have the same problem. TV was JUST out of warranty. Sceptre part number is X37SV-Naga and the cost - $285.00 plus $20 shipping. Non-refundable, no returnable.
The TV is of course going to de-solder the board within a year again, so either a good heat sing on both thermistors is in order OR a law suit against Sceptre is in order for putting us a risk of fire.
SOURCE: Vizio GLV47 LCD HD TV No Picture No Sound?!?!?!?!?
Without seeing the set and takig some measurements, I can't say for sure where the problem is, but the part info is listed below. These can be purchased through tritronicsinc.com. Please note that these boards have a "core" cost. This means that the "core" amount will be refunded to you once the defecive board is returned.
Dan
Power board: 0500-0510-0340 Cost: $102.97 Core: $10.00
Main board: 3647-0072-0150 Cost: $202.68 Core: $40.00
SOURCE: av-48p776 rear projection jvc. power surge from a lightning storm
You will need to replace the convergence chips located inside the set. Typically a repair shop will charge 150-250 to fix it. Good luck
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
