Question about MTX Car Audio & Video
Mtx thunder 1000,1 amp in protect mode has not been moved and was working great for long time all we did is unhook power line fuse when car went in for repair.
Running 1 mtx 12 inch sub
Posted by Anita Janechek on
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
Mtx thunder 6152 is getting way to hot and shuts its self off when it get really hot
okay, first thing i would do is turn down your gain. Sounds like you are over working the amp thats wire your amp gets hot and shut off, it's going into protection mode. Is your amp enough for your subs. Some times not getting enough power to your amp might do this too. But if your subs wattage is way over your amp watts, you need to upgrade your amp. Also check your subs and see how the are wired up with the ohms, And see if your amp can take a 1 ohm stable load or how ever it's wired up at. hope this was helpfull.
May 13, 2010 | MTX Thunder 6152 Car Audio Amplifier
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Jan 31, 2010 | MTX Thunder 421D Car Audio Amplifier
Low output from T8302 MTX Thunder AMP
It sounds like an Ic is to blame, Check individual channels to find which one is not working?
Jun 11, 2009 | MTX Thunder 8302 Car Audio Amplifier
MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Jun 03, 2009 | MTX Thunder 421D Car Audio Amplifier
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Fuses
Check the ohm measurement of the speakers make sure they are about the rated ohms.Check them UNHOOKED from the amp. (Useually 4 ohms.)
Try different subs.
May 25, 2008 | MTX Thunder 3401 Car Audio Amplifier
4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Mar 08, 2008 | Car Audio & Video
Car Audio & Video Logo
145 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
