SOURCE: Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
SOURCE: Cleaning the bissell little green
Bissell 1425 works great, but today will not ****! Spray is fine....just no suction, even without any attatchments.
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you
need and a manual you can view:
Bissell 7901 Belt and Manual
Testimonial: "just what I was looking for thank you"
Most likely the pump belt is worn and needs to be replaced. Here is the belt you need:
Bissell Proheat Pump Belt
SOURCE: My bissell 2x proheat deep cleaner does not dispense the shampoo when I'm cleaning
Here's a quick link to troubleshooting steps. http://www.bissell.com/FAQDetail.aspx?id=1131&cid=ccsocial
