Question about Hitachi Televison & Video
I had remote control for hitachi rar 36z i can turn on and turn off using remote.
What shall I do to reset the remote.
Posted by bernard on
    Top Expert:
  • Hitachi Master
  • 76,416 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Jun 18, 2017
Good day..i ask some question about my tv.what shall i do if the picture is zoom in and i cannot found in remote control setting.thanks.
Try a Hard Reset. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the sites linked here. Pull up older posts.
http://electro-medical.blogspot.com//
Oct 09, 2018 | Televison & Video
This is my universal remote control for the lg tv..i have tried all codes you have given but still the indicator red light blinks as i input the second number of the code.
HI NENITA, Did you try these codes--> 024, 040, 098
Setting Steps: Input Code
1.) Find out the 3-digit code for the TV that you need to control from the "Code list" In case there are several groups of codes available, please use the first group at first; in case that your TV brand has no matching code in the code list, please try the "Search For the Correct Code" mode described later.
2.) Press and hold the "Setting" button at first, then press the "Power" button. Release both buttons after the indicator light illuminates, indicating the status of code input; in case the indicator light is in other status, it indicates that it's yet to enter the code input status, and this step shall be repeated till the light illuminates.
3.) Input sequentially the 3-digit code that you have obtained. The indicator light flashes once when one digit is input. After the input of the code, the indicator light extinguishes; in case indicator light flashes twice successively, it indicates that your input is wrong and you need to input again.
Note: In case the indicator light keeps illuminating after two flashes, you only need to input the correct 3-digit code and do not repeat Step 2, otherwise Step shall be repeated for resetting.
4.) When the Indicator light extinguishes, the setting ends, then you can remotely control your TV with the remote controller.
Apr 17, 2016 | Universal Remote Control Televison & Video
Reset my remote,i changed the batteries,my light on the remote is just blinking all the time what shall i do.
1. The button that is pressed to give command may be stuck and need to be released
or the touch pad needs to be cleaned, that is done by carefull opening up by someone who has done it before.some rcu are screwed together, some have to be prised open at the side and being careful of the buttons not falling away especially the colour ones
Jan 16, 2015 | Televison & Video
97 avalon removed battery and tripped alarm car will not start
This is how to reset the alarm Roll up all windows exit the car lock all doors with the remote, then wait ten minutes, unlock the door using the key, that will reset the alarm. without remote I found this, have no idea if it will work, but worth a try!!
Mar 06, 2018 | 1997 Toyota Avalon
How to reset my techwood tv
My tv is stuck on wireless display I don't have a remote to get it off what shall I do
Apr 25, 2012 | Thomson Televison & Video
Is there Liebert NFORM software for normal PC windows 7? and if there please send me A demo .
Liebert ® Nform Software
GUIDE SPECIFICATIONS
1.0 GENERAL
1.2 SYSTEM REQUIREMENTS
A. All material and equipment used shall be standard components, regularly manufactured and available and not custom-designed especially for this project. All systems and components shall have previously been thoroughly tested and proven in actual use prior to installation on this project.
B. The manufacturer will furnish or supply a site-specific Critical Infrastructure Management software system based on customer requirements. The system must be a software-only solution; no substitutions will be accepted.
C. The system architecture shall consist of network interface cards that will be installed in all critical infrastructures that at a minimum support HTTP and SNMP simultaneously.
D. The system shall receive SNMP traps from managed equipment and display the alarm notification in a graphical user interface.
E. The system shall be based on SNMP Open Protocols and integrate seamlessly with Emerson Network Power, Aperture® software suite and Network Management Systems.
F. Open protocol support shall include:
· HTTP(s)
· TCP/IP/v4, TCP/IP/v6
· SNMP v.1, SNMP v.2
G. The system will have the capability of being remotely monitored and managed 24 hours a day, 7 days a week by the manufacturer.
H. The system shall have the ability to be deployed world-wide.
I. The system shall operate as a client-to-server application.
J. The Web interface of each managed device shall integrate directly into the system.
K. The system shall support Enterprise level databases including Microsoft SQL.
L. The system shall support exporting of all recorded parametric trend data.
M. The system shall operate on a server defined by the customer. Specific server brand or function is not permissible.
N. The system shall support virtual server environments by default.
O. The system shall include at no additional cost one (1) year of Software Assurance.
May 09, 2011 | Liebert OpenComms Nform for PC
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
My central locking has gone silent. How shall i TURN IT ON? secondly, the alarm does not on if something hits the vehicle.
hold the lock button down on the remote for 7 seconds,and if it honks it is reset.
May 18, 2010 | Cars & Trucks
MY 3 PIECE GEMMY CHRISTMAS TREES STOPPED WORKING THE SPEAKER FOR MUSIC JUST KINDA HUMMS AND THE LIGHTS WILL NOT WORK
Here's what you do... This is for the trio christmas tree light show.
What you need.... small precision pointing tool.
On the largest tree base electrical box there is a push button. Press and release that button. A red led will flash indicating the box is in sync mode. turn the remote on and on the back of your remort, there is a small hole with the words reset over the top of it. Using the small precision pointing tool, press the recessed button and release. The remote will sync to the base unit. Walla!! Merry Christmas to all!!!
Nov 29, 2009 | Gemmy Toys
I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Nov 29, 2008 | Audio Players & Recorders
Televison & Video Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
