I have a Tork DTS 200B timer that has been in service for 11 years. After a recent power outage (which occurs several times a year) the current time must be reset. This has not been required after other power outages. I suspect there is a battery to maintain the actual time. This timer is used in conjunction with the weekly test of a town weather warning siren.
SOURCE: Microwave runs but does not heat.
Generally, the most common causes of a failure to heat are: - bad door switches or door switch mounts If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383 For more help from Emerson http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
SOURCE: Toyostove Laser 73
There are 2 fuses on the mother board. You can go to the Toyotomi website download the Owners Manual and look at 49 and 50 in the parts list and picture.
SOURCE: power outage recently. won't turn on
There can be many reasons why your dryer will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
SOURCE: PDP4247 Akai. Cablevision powered.
The tv goes into standby. 2 possible causes:
1 - the power source has aged and the voltage it delivers to the other components of the tv (in particular the control processor) is no longer stable: if the voltage drops below a certain level the processor just shuts down, putting the tv in standby. The power source will have to be checked and the aged components replaced (it's most likely the capacitors).
2 - there is a power fluctuation on the mains power line - the others don't shut down because they have a lower power necessity and they are able to coup with that.. The only way to test and fix that is to run the tv thru a UPS.
SOURCE: I have an APC XS1300. One year old. Very few
Mines, two or three years old and doing the exact same thing, you ever figure out what happen or how to fix it? I took the battery out and it reads 16 volts. I put a 2 amp load (fan) on it and it pulls fine, so I'm reluctant to buy a new battery pack for it now.
