Question about Samsung SCX 4200 All-In-One Laser Printer
Printing squares instead of text
When printing off of Firefox and some sites in Explorer, the text prints in a small blank squares as if a font isn't recognized. Some text in the SmartPanel is like this too. No problems for graphics, .txt, or .doc files.
Thanks a million,
Dave
Posted by Dave_Arles on
Anonymous
  • 417 Answers
Reinstall the drivers failing this goto printers and faxes right click on the icon and select properties. Select Advance tab at the top of the now open window then select print processor once in there select a different graphic mode ok and close then test.
Thanks J
Posted on Jan 17, 2008
How do i make my print larger onmy kodak esp3.2
I depends upon what you are printing from. For example, if you are printing from a web page, sometimes there is a selection available on the web site to increase the size.
If the problem is the size that is printing out, I usually do a "cut and paste" of the text from the web page and then paste it onto a blank document page. You can then change the font and/or size of the text.
One other suggestions is in the "printer" settings, select the choice for "no borders" or "no margins" and that will allow the text to expand slightly.
Sep 21, 2014 | Kodak Office Equipment & Supplies
How to change font size
The font size that appears within printed documents has to be adjusted in the application you are printing from. For example, if you are printing a Microsoft Word document, change the font while editing the document in Word. If you are printing a web page, you will need to change the font in the web browser settings (Chrom, Firefox, IE)... for Chrome, here are the steps:
  1. Click the Chrome menu snp_2696434_en_v1 on the browser toolbar.
  2. Select Settings.
  3. Click Show advanced settings.
  4. In the "Web Content" section, use the "Font size" drop-down menu to make adjustments.
Some websites prevent the browser from changing just text size. For those sites, Chrome won't be able to adjust the font size.
Jan 15, 2014 | Office Equipment & Supplies
Change font size in e mail
The printer prints whatever it's told to by the computer. Your printer really doesn't control the fonts.
When you are printing stuff from the internet (web pages, email, etc.) the reason for the small print is that it is related to the size of the monitor and it's viewing setup (the higher the screen resolution, the smaller the print will be when printing it out even though it looks good on the monitor).
One way you can make the print larger when printing internet stuff & emails is by changing the print view size on the screen to a larger size in your web browser (this is separate from your other setting you've already setup). Go to the menu bar at the top (i.e. Internet Explorer), click on "View," then "Text Size" then select a size like "Larger" or "Largest" (something higher than what you're currently set to.)
Another method is to go to your menu bar at the top of your web browser, click on "File" then "Print Preview". At the top of the window there should be a small window with "Shrink To Fit" in it. Click the arrow for a drop down list and choose something probably above 90% or more (maybe 100 or 125%) and see how it changes the print size of what is to be printed out.
The only other method is to copy & paste the text into a text editing software like Word and adjust the text size there. If you're using a text program, then you simply adjust the size of the text to a 12 or 14 point, or larger, font size (adjust depending on the font and size you need) and that should do the trick.
Apr 21, 2012 | Canon PIXMA MP470 All-in-One Printer
When I print my telus bill the font is very small, hard to read.. (I wear glasses). When I print a copy of the bill from PDF , the font is larger ??? When printing from thr internet,ie: recipes, if I
Which browser are you using? Internet Explorer? Mozilla Firefox? Opera? Google Chrome? Safari?
If you are using internet explorer: Click Tools/View/Text Size and change it.
If you don't see tools at the top of your browser on a line that says File/Edit/View/Favorites/Tools/Help look for tools over on the right then click it and select Toolbars, then select Menu Bar and it will stay at the top of the browser so you can just click Tools/View/Text Size
If you have Windows 7 press and hold the ALT key for the menu bar to appear at the top of the browser.
Apr 01, 2012 | Computers & Internet
How do I change the font size ?? The lettering is far to small.
Apr 01, 2012 | HP Pavilion dv6000z Notebook
When I am on the internet and want to print something, how can I get the print to print out larger in order to read it better? I have a HP Photosmart C4795 printer. Thank you.
There are lots of browsers so I don't know what you are using. Google Chrome, Firefox, Internet Explorer, Safari are some of the browsers.
Usually the browser has settings for this. Sometimes It's as simple as looking for a setting for font or zoom.
Look for things in the menu such as --settings, tools, options, etc.
Usually the choices will be things like - smallest, smaller, normal, larger, largest. Pick a larger zoom or font and try to re-print.
When you pick the larger size the text on the screen will be bigger, and should also print larger.
Feb 11, 2011 | HP Office Equipment & Supplies
Printed font size too small
Most web browsers have an option to change the text size on the page you are viewing. In IE8 it is accessible through the Page menu, Text Size. It defaults to Medium, and there are 2 smaller sizes and 2 larger sizes available.
May 29, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Prints very small
The font size is going to be controlled by the program you are using. For normal word processing you would use a 10 or 12 point font.
If you are referring to printing from a browser like Internet Explorer, you can change the font from the Internet Explorer menu VIEW > TEXT SIZE > MEDIUM (normal).
Note: Internet Explorer font settings effect Outlook Express too.
Nov 24, 2008 | Lexmark X2500 All-In-One Printer
Printer font size
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
Notepad and Microsoft Word
Please perform the steps given below, if you are printing from note pad nd Microsoft word:
Click on Format.
Click on Font.
Select the desired font under Size.
If you are printing from any browser, then I request you to perform the steps given below to change the font settings in differ browsers.
Following are the instructions to decrease or increase the font size in various browsers:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
Aug 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Change font size
Two things you can try!
1.From your Browser you can change text size in the browser.
I am using Internet Explorer for this example
Click on View from the top tool bar, Select Text Size.. you can increase and decrease the text size of a web page.
2.Before you print check Print Preview and Increse the page size.
My Browser defualt to Shrink to Fit,
I can change that to 120% and it will print the page very large.
Most programs in Windows will offer a Print Preivew
there you can make adjustments, and this can also be accomplished with Page Set Up..
Hope this Helps
Jul 03, 2008 | HP LaserJet 4 plus Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
146 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
