Question about Ps Office Equipment & Supplies
Top cap removal
Powershred PS 30 cannot get inside to see which gear is damaged
Posted by LeRoy Fuehrer on
4 Related Answers
Anonymous
  • 58 Answers
SOURCE: Powershred PS 70
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
Anonymous
  • 32 Answers
SOURCE: Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
Posted on Sep 01, 2009
Edward
  • 105 Answers
SOURCE: I have a Fellows Powershred ps 60cc and removed
the shredder has a safety switch that closes when the unit is put back on the basket. check under the cutter head for the hole that has the switch and check your basket for the acuator put together so they will line up
Posted on Nov 17, 2009
ROCKIT957
  • 41 Answers
SOURCE: The plastic gear in my Fellows Powershred PS 60CC
WHICH OF THE PLASTIC GEARS FAILED? FELLOWES HAS A REPLACEMENT THAT CHANGES A PLASTIC GEAR TO A STEEL GEAR-A GREAT IMPROVEMENT.
Posted on Sep 22, 2010
Do you know where I can get a replacement powercord powershred ps30
power supply are Fellowes Class 2 model (A57-013-15Z01)120 vac 60hz 39w 15vdc- 1.4 amp
The above is the specs for what you want. You can buy any generic or brand of power supply as long as your specs are the same and, of course, the ends (plugs) are the same as what you need. The very large on line store has many options
Jan 24, 2018 | Office Equipment & Supplies
Looking for a basket for a fellows 65c
You can only buy new one or block a microswitch inside. Basket from Fellowes PS-67Cs can be used too. If you use this shredder privately just block the microswitch.
Nov 10, 2014 | Fellowes Powershred PS-65C Medium-Duty...
Hi my shedder PS -60 has the red light on but nothing is jammed - can you help?
I don't have your shredder, but check to see if the top part where the shredder mechanism is closes completely over the trash can. If it is not lining up, it may have a shut off switch. I had put a plastic bag inside mine to catch the bits, and it bunched up at the part where that connection needs to be clear and it stopped. When I smoothed that area, or removed that bad, it worked again. GOOD LUCK!
Jul 24, 2014 | Fellowes Powershred PS-60 Shredder
Part #540307-1 broken
Here is a link you can get the whole gear assembly for $30: www.sportslinkup.com/shop/0-Fellowes-gear-1.html (P-55C Gear Kit for Fellowes Shredders part #205993).
I need the same for my Fellowes P-57Cs shredder, same broken gear 540307-1
Sep 26, 2010 | Fellowes Powershred P-55C Shredder
One of the gears in my sb-97cs has broken. The motor runs but the broken gear prevents the teeth from rotating and pulling paper into shred. I have spoken with people at Fellowes on the phone and they have...
I have the same problem with a stripped gear, to remove the top i found it best to place the shredder on its back, then with a pozi screw driver there are 5 screws securing the top in place, these are inside the shredder above the paper bin, 1 in each corner and 1 in the centre.
Hope this helps.
Jan 14, 2010 | Fellowes Manufacturing Powershred SB-97CS...
I have a Fellows Powershred ps 60cc and removed the shredder top to empty the shredded documents. When I put it back on, the red light will not go out and it will no longer work. It was working perfectly...
Nov 03, 2009 | Fellowes Powershred PS-60 Shredder
The plastic gear in my Fellows Powershred PS 60CC paper shredder is ruined. Is it possible to buy a replacement gear anywhere?
Oct 06, 2009 | OfficeMax 0M96431 Shredder
May 16, 2009 | Fellowes 3011001 Shredder
The paper will not go through my shredder
Can you actually see the cutter blades rotating? I have seen gears broken and you can hear the motor running but no blade movement. Remove the screws lift the top off carefully because their is a short ribbon cable connected to the main board and can easily be damaged. Of course unplug from power outlet first.
Gears and motor can be puurchased.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 12, 2009 | Fellowes Powershred 420-2HS High Security...
Powershred PS 70
Good luck, Tom
Apr 18, 2008 | Office Equipment & Supplies
Top Ps Office Equipment & Supplies Experts
Marvin
Marvin
Are you a Ps Office Equipment and Supply Expert? Answer questions, earn points and help others
