1996 Plymouth Breeze Logo
Posted on Jul 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my fuse keep blowing for my tail lights in my 96 plymouth breeze ?Every time I put fuse in it cut the lights on the fuse blows?
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Jul 26, 2009
Anonymous
Expert
Level 2:
Answers
83
Questions
0
Helped
47649
Points
272
The fuse keeps blowing out because there is a short circuit. Check the tailight sockets for corosion. Is there a tow package wiring installed?
Anonymous
Level 3:
  • Master 3,600 Answers
Anonymous
Master
Level 3:
Answers
3600
Questions
Helped
1576606
Points
11774
First remove the bulbs then put in fuse if fuse does not blow then your wiring is good and it is in one of the bulbs replace one bulb at a time to see if the fuse blows, when it blows on the light you put in that bulb is your problem, sometimes you can't see the bulb is bad so buy a replacement bulb and try again if it does not blow you have fixed you own problem, if it does not your out ten bucks and it's time to take itto a mechanic, Hope this helps and if it does please rate me.
I have a 96 grand am and it keeps blowing the fuse for the tail lights and dash only
There is a short in your wiring.. i would look first near the tail light connector in the trunk.. and around the tail lights. If it blows that quick it is a dead short and you should be able to find it. move wires around and try another fuse.. if it stops blowing look at the last place you were checking the wires.
1helpful
1997 Plymouth Breeze blows 20amp ign./ starter fuse when starting
When this fuse blows on a consistent basis, the large majority of the time it is caused by an internal short in the starter motor solenoid. The fix is to replace the starter motor.
1helpful
Why does my tail light fuse keep blowing?
look for a wire short in trunk or bad tail light socket that bulb is in seen this before more than once!id you put a cd player in this or radio or anything lately
1helpful
Tail light fuse blowing
If it has a towing package harness,it might be in it.Remove all the tail light bulbs,and put a new fuse in to see if the fuse will blow.If it does,check the head light switch ,and the dimmer for the dash lights for a short.If the fuse does not blow,with all the bulbs out then look for a bad light socket shoring ,out,by putting one bulb in at a time,and when the fuse blows,that will be the socket that is bad.
1helpful
My 96 T100 blows the tail light fuse when the head lights turned
ck rear tail light sockets for cracks broken wires. and terminals in connectors are not touching
96 bluebird le grand tail light fuse keeps blowing?
Anytime a fuse constantly blows, you either have a short in your wireing for that components circuit or the component itself is faulty. Inspect the wiring harnesses for each taillamp assembly and ensure no wires are damaged or loose. Also inspect wiring at the fuse box.
My friend installed stereo and now my dash lights & tail lights don't work
you blew out your tailight fuse should be ten amp fuse inside engine compartment if it blows out again then the cd player is hooked up incorrectly.
Mt plymouth breeze keeps blowing fuses wont even start
If it is blowing the starter fuse you probably have a bad starter with a high draw.You might want to take the car to a repair shop and have the starter circuit tested.....I hope this helps you.
Top Plymouth Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Plymouth Expert? Answer questions, earn points and help others
