Question about Ps Video Game Consoles & Games
SOURCE: After formating PS3
You need to plug your sixaxis controller to the ps3 with the usb cord to marry the control to your system. after unplugging and pressing the home button it should link up. If not try using another usb cord or plug on the ps3.
Hope this helps.
Posted on Apr 04, 2008
SOURCE: how to get sound volume controler
1. Install the Sound Drivers.
2. Green colour connector is Audio out put.
3. go to control panel , check the sound selection
Posted on Nov 22, 2008
SOURCE: Controler will not turn channels
If you still have the manual that came with remote, reprogram the remote for your receiver. The RC32 is has had some issues because of all the new Directv components available
Posted on Jan 08, 2009
SOURCE: Ps3 wont connect controller
if your controller works fine using the usb cable then is not your blu tooth card inside the ps3 the blu tooth only works when the contoler is not connected with the usb cable try to push the PS logo for 2 times in your control using the usb cable and then wait a few seconds and see what happend
Posted on May 29, 2009
SOURCE: my ps3 i acting weird i think it might have a
Ok, unless you want to console into your PS3 and manually try to clean it or check to see if a virus is making it act up. I would recommend resetting it to default factory settings.
Hard Reset procedure for the PS3
Be sure to backup your settings/games saves by doing a System >
Backup on your PS3 or you may lose your game saves! Also, this is a
last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format
via System > Format. (will take approx 3 1/1 hours). You may need
to have our AV cables ready if your using HDMI (in case HDMI isn’t
detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully if there is or was any type of virus it will defiantly be removed. If there is some other type of problem having to do with the hardware, then you are going to have to send it to Sony for a replacement.
Hope that helps.
Posted on Aug 22, 2010
Feb 02, 2011 | DreamGear Dgps3-1383 Playstation(r) 3...
Jan 28, 2011 | Video Game Consoles & Games
Jun 29, 2010 | Sony PlayStation® 3 (60 GB) Console
Jun 15, 2010 | Sony Playstation 3 (PS3) Console
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
Feb 19, 2009 | Sony Dual Shock 3 Controller for...
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Feb 12, 2008 | Sony Playstation 3 (PS3) Console
Nov 18, 2007 | Sony Playstation 3 (PS3) Console
1,390 people viewed this question
