Question about Radio Shack Measuring Tools & Sensors
Need to change time and date on Radio Shack Weather Station Model 63-256
Posted by Russell Cole on
5 Related Answers
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
Posted on Jan 29, 2008
Anonymous
  • 405 Answers
SOURCE: Radio Shack 17-6020 Paging system
Good Day,
See this link for all available documentation:
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=17-6020&Name=Pagers&Reuse=N
Hope this helps
Posted on Jul 09, 2008
guru_fixya
Natarajan Ramasamy
  • 944 Answers
SOURCE: The weather Forecast Icons don't change on my
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 11, 2010
Rielle Burst
  • 164 Answers
SOURCE: Midland weather radio model-100 I need the
Click this link- WR-100 Weather/RDS Radio Manual. I got this link from the Manual section of Midland WR-100 Weather/RDS Radio web page on this website.
Posted on Sep 27, 2010
john milligan
  • 514 Answers
SOURCE: need instructions for model #2316 La Cross
per the manual at http://www.lacrossetechnology.com/2316/manual.pdf on page 2 section 5 the unit sets its self to the world time radio signal from boulder colorodo on its own after it get the security code from the sensor pack.
Posted on Nov 18, 2010
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
CHANGE LOCATION ON MY 348NC weather station
Press and hold mode button till hour digits flash then press 12/24 or rcc buttons to change then press mode button but pay attention after time date is updated location will flash then you pick the city. Just don't go to fast or you will miss it! Hope this helps.
Aug 21, 2014 | National Geographic Home Weather...
VIKING ART:02041 radio controlled weather station
How do you do to recive aut time and date from the Braunschweig clock in Germany ?
Aug 24, 2013 | Viking Electronics Measuring Tools &...
Need a manual for model cs1203 craig weather station
To change the time, press the time button. When it goes to 2000, you will see the date flashing. Adjust using up and down buttons. Then press the time button again. You can then use the up and down buttons to adjust the time. Finally, to toggle between F and C, use the up button by itself. To adjust between 24 and 12 hour clocks, press the down button.
Jun 10, 2012 | Measuring Tools & Sensors
Radio Shack thermo hygro sensor model 63-1090 reads everything except the outside temp
I ran into this problem and note that in the manual is states for "best results" the sensor should be powered up before the station. I had the station running and it wouldn't lock even after several hours. When I powered it down and brought it back up, it saw the sensor just fine...
Jan 15, 2011 | Radio Shack IndoorOutdoor Thermometer with...
Need instructions for model #2316 La Cross technology weather station. How do I set the date and time?
Nov 17, 2010 | La Crosse Technology Technology Weather...
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Measuring Tools & Sensors Logo
338 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
