Washing Machines Logo
Question about Electrolux Washing Machines
Hi . I have a electrolux EDP2074PDW INTUITIVE 7KG ADVANCED DRYER IT STARTS THEN STOPS AND BEEPS IT SAYS E.H.O ON THE DISPLAY CAN SOMEONE TELL ME WHAT THE CODE RELATES TO PLEASE
Posted by Paul Huisman on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Posted on Feb 18, 2009
Anonymous
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Posted on Apr 19, 2009
Anonymous
SOURCE: dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Posted on Apr 29, 2009
Anonymous
SOURCE: fisher and paykel intuitive washer what is a code 43 please
I had a faut 43 showing on machine. I took the advice and removed the out of balance sensor which has the white and yellow wires attached. I did not pay attention which wire goes where, silly me, Can anyone advise which wire goes where, connectors on side and end of switch
Posted on Jun 28, 2009
Anonymous
  • 327 Answers
SOURCE: Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
The drain pump may be blocke.check www.serviceforce.co.uk
Thanks
Posted on May 21, 2010
1helpful
I have a edp2074pdw dryer an it is showing a e40 error code
That indicates that the door is not closed.
Ensure that nothing is preventing the door closing successfully and try again
EHO message on Electrolux EDP2074PDW dryer
On Electrolux dryers, the EH0 (EHO) error indicates a problem with the incoming voltage at the power supply. This can be due to a problem with the electrical outlet, the power supply or the circuit board.
First unplug the dryer or shut off the circuit breaker. Check if the outlet is working by plugging something else into the outlet and checking if it works. Leave the appliance off for 30 minutes or an hour to see if the error resets. If you recently had a power outage, this might clear an issue from an electrical surge. You may want an electrician to check your wiring.
After that, you will have to check if the power supply is working properly or if the circuit board is getting the incorrect voltage information. There should be an wiring diagram and test sheet tucked into the dryer. It's usually in a space accessed from the back of the dryer. Replace the faulty part. If the dryer is under warranty, contact Electrolux and have them service the problem.
I hope this. The parts diagram is available as a PDF here: https://spares.bigwarehouse.com.au/index.php?cPath=64689_77656_94810 .
1helpful
Electrolux 7kg sensor dryer stopped starting to spin unless you started it by hand now nothing works at all.
what do you mean start it by hand,do you mean if you spin the drum by hand helping it to spin it starts if so you have a bad motor.also next time send the full model number off of the dryer.
It comes on for 2 mins and then E50 comes up on display,sorry its an Electrolux Inspire 7Kg Dryer.
is it a sensor dry? is there damp washing in there when you are testing it?, or is it empty as this will tell the PCB to stop as it feels no moisture in the machine
Jan 16, 2011 • Dryers
058 model does not fill up continuously, water in and stops starts and stops does that a few times and stop completely and beeps all lights stays on. Please help. Thanks
I have the same problem, just checked the switch and its all ok. But the machuine also stops and starts when its trying to empty after the last rinse cycle to start the spin cycle. Starts to drain then stops and repeats, it does empty some without stopping but starts to go silling when its nearly empty?
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
