Question about Zeiss Science & Laboratory
ZEISS HUMPHREY 750 SYSTEM STATRTUP STATE 16
2 Suggested Answers
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: i need the operation manual
You donot get free manual for this equipment.You need to pay for you manual .You can get the manual for zeiss humphrey 5015 from below website
http://business.shop.ebay.com/Healthcare-Lab-Life-Science-/11815/i.html?_nkw=humphrey
Thank You
Posted on Sep 02, 2010
VIPUL J MISTRY
SOURCE: Humphrey Zeiss A scan model 820 will not finish
there is problem in software module located on back side of instrument.remove two screws of software module,pull it upward and remove it.there may me missing some part or loose contact or malfunctionig of it.
Posted on Dec 09, 2011
How can I turn off the zeiss Humphrey? only from the shut down button or there is a function from the software?
This is a brand name, not a specific device and model. That said, here is a page describing mode switch in the setup screen using the touch screen for a specific device. I assume a touch screen would have an icon for turning a device off.
Zeiss HUMPHREY 720i User Manual System Setup
Jun 07, 2018 | Zeiss Science & Laboratory
Why does my zeiss humphrey visual field machine keep shutting down?
Sounds like a heat, thermal issue. You may have a non- functioning cooling fan somewhere inside. There are several of them so don't be fooled if you hear one of them running. Same issue happens with CPUs on PC computers. Will suddenly shut off if too hot.
May 24, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Zeiss humphrey system startup state 19
I believe "state 19" is a weak main illumination bulb. Not sure if it's the same on your 740, but that's what the problem was with our 750i. Even though the bulb appears to be working, they dim over time and won't pass the start up calibration checks. On ours, there is a round access panel on top of the unit to service this bulb. Just be careful removing the bulb and don't bump any of the clear optical wheels. Part # 2660021106082 (for 750i. not sure about 740) Call Zeiss to confirm. Realize this is an old post so info is for future readers.
Mar 27, 2014 | Zeiss Humphrey 740 Visual Field Analyzer
Battery low in Zeiss Humphrey Acuitus 5015 Autorefractor Keratometer, what can i do?
The batery is a integrated circuit that is soldered to the Mother Board. You should disolder that circuit in order to replace it
Mar 21, 2014 | Zeiss Humphrey Acuitus 5015 Autorefractor...
Autorefractor Humphrey Zeiss Acuitus 5015 not sharpen the image
The problem is in the mainboard, look for j conectors, and try to see if any is released.They control the step motor who can make the camera focus
Aug 26, 2013 | Zeiss Humphrey Acuitus 5015 Autorefractor...
Repaing the corneal topography machine atlas, humphrey zeiss
I have the same problem, the hard drive crashed. Need original install disks. Anyone have?
Mar 29, 2013 | Zeiss Humphrey Atlas Eclipse 992 Corneal...
Science & Laboratory Logo
1,560 people viewed this question
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
