Unscrew the top half of the reel cover, next there will be a small nut on a center bolt, remove that nut , lift that rou?d plate and there's your spool.
I contacted customer services at Hotpoint today and have been informed that model 11761 is no longer available and as the handles which I have been informed do not normally break they concidered as consumables they are not stocked.
have you called the manufacturer?also there is a forum on line i think its called fish forum .com but I'm not sure.I'm sure you will find some one on that forum that will have what you need.
hi,
If the bottom portion of the metal disk inside is "curvy"the line is wound by the curves.Its kinda hard to explain.Try twisting the metal "disk and pressing down lightly while turning the handle,this should put the take up parts in the right alignment.That being said,I would go spend 15 bucks at wal-mart or similar store and buy a real reel.I am a semi-professional fisherman and I dont use real expensive gear,but zebco is probably the worst equipment available.I use Okuma or Diawa...they have some low end models that are very inexpensive and work just fine.
You must remove the handle from the gate, this is done by removing the plastic tail-gate guard. On in side of gate are some torx screws , remove screws and gate guard will come off. Then there are some more torx screws to remove steel acess pannel, the tail-gate handel will be held in place by 2 10 mm nuts . After removal of nuts the handle will come out, inspect handle for brakeage or rust. replace if nessesary.
