Question about Singer Sewing Machines
Thread is all bunched up in loops on backside of sewing piece on my singer stylist 513 machine
Posted by Leesha on
R.A. Ellis
  • Singer Master
  • 12,731 Answers
Bird nests (also called thread nests). Most common cause is because the presser foot is not Raised when the top thread is being threaded.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Sewing Machine Thread Bunching Up Here Why
Posted on Jun 15, 2017
Sewing bobbin
Found several answers at this site, mostly addressing the tensioner.
Singer Sewing Machine Bobbin thread is bunching up Yahoo Answers
Jan 14, 2015 | Singer Sewing Machines
I teach sewing. A student had a problem with bunched threads on the underside of the fabric. I have tried figuring it out and every so often the thread stops looping. While sewing on the cg550 singer...
Make sure you have the correct bobbin, 66 class. Check the bobbin case. These machines use the apollo bobbin case that tend to get broken and then the thread hangs up.
Apr 27, 2011 | Singer CG550 Mechanical Sewing Machine
No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Apr 10, 2009 | Singer Sewing Machines
The tension is off on my machine. The needle thread keeps pulling so tight that it snaps, and the bobbin thread is so loose that I'm getting loops on the backside of whatever I'm sewing. I thought that...
Loops on the backside mean there is no tension on top ,if the top of the sewing l;ooks good then the bobbin tension is correct make sur eyou are threading the top thread correctly
Aug 30, 2008 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
133 people viewed this question
Top Singer Sewing Machines Experts
tsalagi152
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
