SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
SOURCE: How to program Magellan RoadMate 1200?
Go to www.magellangps.com. Click on "Support" on the top of the screen. On next page, go to "Product Support and Updates" on the right and enter the "Family" (Magellan RoadMaster Series) and the Model should automatically pop in the box (Magellan RoadMaster 1200 - US). Then, click "Submit". On the next page, go to "Manuals" and select "In English" and click. The manual will automatically start to download. Hope this helps...
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
SOURCE: hi,
if you havent updated it yet, you can go here for the update for your model..just look up your model on the right side and download your
update (you must register on magellangps.com to be able to download)
