Question about Hitachi Televison & Video
SOURCE: Hitachi 43FWX20B picture problem
yea take the set to a tech reprogram.or take out the plug and plug it in after 30 min.if the problem does not go.do as i say.good luck.
Posted on Apr 04, 2007
SOURCE: Will not turn on/ black screen
Must be a common pblm. Well it's solved!! we bit the bullet and had the main video board replaced for $400 and all is well.
Exlead
Posted on Sep 29, 2008
SOURCE: Hitachi TV screen adjustment
The easy way to fix this: Click 'Menu' on your remote. Then click 'Setup'. Next, you will have to select 'Screen Position Setup'. This will open a screen that allows you to adjust your TV screen position simply by using the arrow keys on your remote. If your TV is anything like mine, this will work.
(I have a Hitachi 51F710A)
Posted on Nov 28, 2008
SOURCE: i have a hitachi tv model 42edt41 year 2004,2005
I have the same tv and had the same problem. I found a posting that stated to re-solder a connection on the cable for the "y" boards. I used this and my tv is perfect now. The part that needs to be re-soldered is the ribbon cables at the bottom of the tv that go from the boards straight to the screen. On the inside of this ribbon cables there are 4 small components that have "100" on them. On each end of each of these pieces, re-solder them. Since I had my tv completely apart I re-soldered all of them across the bottom. No problems now!
Posted on Oct 16, 2009
