Question about Mercury Boating
2002 mercury 125 outboard will not run on all 4 cylinders
  • Steve P
    Steve P Jun 21, 2017
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Bill Boyd
    Top Expert:
  • Mercury Master
  • 53,816 Answers
Fuel injected model , have the fault codes read
carby models have the entire fuel system cleaned out and all rubber hoses, pump diaphragm replaced as the hoses break down internally and put rubbish in the pump and carby's
do not use e-mix fuels as the ethanol absorbs moisture and that corrodes aluminium bits , rusts fuel tanks and breaks down the rubber components
Posted on Jun 21, 2017
2013 MERCURY 60HP 4STORKE OUTBOARD FIRING ORDER. REPLACED SPARK PLUGS LEFT PLUG WIRES ON COIL, COIL READ 2 3 1 4, PLUG RUN VERITICAL SO DOES #2 FROM COIL GO TO THE TOP SPARK PLUG ETC
try bottom plug on left bank
remember it is a 4 cylinder engine with the leg attached to the harmonic balancer in a car
the firing order is 1342 from the bottom end of the engine
Oct 09, 2017 | Mercury Cars & Trucks
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Mercury outboard problems
check compression in cylinders , ignition coil , if has distribuitor check also
Jun 02, 2017 | Boating
I need the type and info on my Mercury Classic 50 outboard motor
serial number is what you need and try looking on the starter or the switch box ( square box with lots of wires on as they have dates on also ) take pictures of engine in and outside as if decals are original it will date it as well ! take to or email your nearest dealer with all info and they date your engine no problem !
Mar 20, 2014 | Boating
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
Boating Logo
1,134 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
