Question about Hisense Televison & Video
Hello I have a 50h5c Hisense tv ,well problem is my son had the control he was biting it and tv tuened off the red light is on but I press on button on control and tv but wont turn on.
Posted by Arely Aguilar on
  • Arely Aguilar Jun 12, 2017
    It doesnt react to the button on the tv or the on button on the control .
Steven Brandon
    Master:
  • Hisense Master
  • 461 Answers
The quickest way to fix this will be buy a universal remote or the original remote from amazon or ebay. All you will need is the make and model number of the tv for the original remote.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Posted on Jun 12, 2017
  • 8 more comments
    But what does it mean if the red light is on ?
  • Steven Brandon
    Steven Brandon Jun 13, 2017
    It is in standby mode, The tv has power but is turned off. It's been there since the tv was new but you probably never noticed it until your child chewed on the remote and you couldn't turn on the tv. Try removing the batteries from the remote so the tv isn't picking up the signal from the remote and try turning the tv on via the power button at the tv.
  • Arely Aguilar Jun 14, 2017
    Okay I tried it but it didnt work :/
  • Steven Brandon
    Steven Brandon Jun 14, 2017
    Let's unplug the tv for 30 mins then plug it back in. Verify that the red light is on. Unplug any cable boxes, dvd players, and game consoles. We want any possible interference out of the way. Remove batteries from any and all universal remotes just to prevent interference and try to turn on the tv at the tv. If it works start plugging things in one at a time and turn tv off and back on after each one to see if they are interfering. Then do the remotes the same way. Let me know the results.
    I did as you said but it wont work. I took off batteries all cables interfering but no its only three months old,i dont believe something can be broken inside .
  • Steven Brandon
    Everything that you have tried points to it being an internal problem. I think it was just coincidence that your son was chewing on the remote and the tv cut off at the same time now that we have exhausted all other avenues. I suggest you call Hisense and arrange for a warranty repair of the tv. It should be under warranty if it's only 3 months old and you bought it new.
    Okay sure will thank you very much appreciate your help.
  • Steven Brandon
    Your welcome, I wish I could have done more.
    Okay one more question would it be safe to take it to local place where they fix electronics because hisense wil not give service unless I have the reciept.I no longer have it.
  • Steven Brandon
    Yes it will be but I have no idea how much they may charge for the repair.
5 Related Answers
bassplayer97
Ryan Gardner
  • 154 Answers
SOURCE: ps3 wont turn on using controller and power button...
try cycling the power on the back of the console
are the lights blinking on your controller when you press them?
Posted on Jul 11, 2009
Anonymous
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
Anonymous
  • 101 Answers
SOURCE: tv wont turn on
unplug the unit and leave over night. replug the TV in. in the morning to a known good outlet. if this don't work take it to a service center.
Posted on Dec 18, 2010
Anonymous
  • 119 Answers
SOURCE: My tv wont turn on when i press the button, the
The capacitors in the power supply are bad. Take the back off, look at the capacitors, "barrels", if the top is bulging up, they are bad. Caps are around $2 each at radio shack x 6?
Posted on Feb 25, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: red light on my hisense tv keep blinking and the tv wont come on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_2_2012_2_03_27_pm.jpg6_2_2012_2_03_55_pm.jpg
If any or all of this information is beyond you then consider the set is in shutdown as something is wrong===likely in the power supply of the set which is where most of these problems happen.
Posted on Jun 02, 2012
Hisense remote just quit working new
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV.
http://electro-medical.blogspot.com/
2answers
I have a 38" Hisense Smart TV. My son was playing on his Xbox then it flashed a red light on the screen and turned off. Standby light is still on but wont turn on. What could be wrong? Any help please
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
MY HISENSE TV IS NOTT RESPONDING TO THE REMOTE CONTROL COMMANDS ALTHOUGH THE REMOTE IS BLINKING. MY REMOTE SERIES IS EN-31603 (IT CAME WITH THE LCD 32' HISENSE TV)
I have the same problem, NOTHING to do with batteries.BUT if you press the that blinking (red) button and hold it down and THEN press the option you want (channel +/-, volume +/- etc) the controls work. Im looking for an answer aswell to return it to its previous state where I dont have to do that!
USER MANUAL FOR LTDN55K560RWAU3D
My tv switched off while playing. It does not want to switch on when I use the remote control. It has a red flashing light on the front bottom left corner that is flashing. I switched the tv off for 45 minutes, but it does not want to go on when I press the on button on the remote control. I even tried to switch it on manually by pressing the on button at the back.
Antsig codes for hisense ap592
Universal remote codes to check up with Hisense Brand TVs are: 0073 0182 0216
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you want more details, check this.
Code remote control universal hisense LHDN32V66AUS 32 "
Hello
Four digit universal remote code for Hisnse TV are:-
0073 0182 0216
Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Is there a universal remote that will work on hisense model HYDF-EP209C1
Hello
Just buy one [ PHILIPS CL 034 ] model universal remote control. Your Hisnse TV is listed in its codes. Codes and proceedings are given below:
0908 0819 0223
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
6. Press and release MUTE to install
the code
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds
OK.
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
