Question about Kodak Office Equipment & Supplies
Kodak Scanner i3400 E13 error code.
Says to turn off then on. Does not work. I cannot find anything to help with this error code
Don A
  • Kodak Master
  • 3,175 Answers
The manual for this scanner indicates the user should check the cabling connections. If securing the cabling does not fix the problem, the manual recommends you call the service. Check that the cables are securely plugged in and that there are no bent pins or damaged to the connections. If you have access to a cable like those utilized or can borrow such a cable, there is a chance that you have a bad cable. A users manual is at the link below. PDF file.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjyloqRsLnUAhVH4oMKHckWDFwQFgg2MAI&url=http%3A%2F%2Fwww.aceperipherals.com%2Fbrands%2Fkodak%2Fi3400-scanner%2Fi3400-scanner-user-guide&usg=AFQjCNGM5Eid46yLuD9hmiFZxwZzbxo_2g&sig2=KRj3JlxgKOwbjpMZj8p4RQ
Posted on Jun 12, 2017
Miele KM-493 induction stove. What does error E13 indicate?
  • Error code E13 error showing on display
  • What causes an E13, E 13 error code on the Induction Cooktop control panel?
  • Error code 13 on Induction Cooktop control panel
Cause:
  • Universal OFF key failure
Troubleshooting:
  1. If the controls are wet or water made contact with them, dry off the controls.
  2. Turn off then back on to reset.
  3. If the error persists, reset the unit at the circuit breaker.
  4. Turn the unit back on to see if the error code cleared.
I need help for error code E13 shown in Kodak i3400 model i have already restart and properly disconnect and connect all cable but issue not resolving SO PLEASE NEEDFUL
E13 is a Camera CPU communication issue , try re-seating the Flat cables going between the CPU board and the cameras they are a big problem!
Kodak scanner i3400 error e73
e73 is A USB command failure. Check to see if the scanner is connected to a USB 3 port. A USB 3 port can be identified by the port being Blue in color or have the letters "SS" (Super Speed) near the port. Kodak scanners behave strangely with USB 3. With the unit turned off, please connect the scanner to a USB 2.0 port. Additionally, download and install (as an administrator) the most current drivers from Kodak.com which alleviates 9 out of 10 issues.
What is error code e13 on cannon pixma mg3122
E13 means that the printer cannot detect the ink level. Press and hold the 'Stop/Reset' button for 5 seconds to continue printing.
2answers
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
E13 error code
services is costing high better buy canon or nickon cam
2answers
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Top Kodak Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
