Cortney Parrent Posted on Jun 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a manual to set up my frisby FS-5500US surround sound system. I want to hook it up to a tv.
Don A
Level 3:
  • Frisby Master 4,384 Answers
  • Posted on Jun 12, 2017
Don A
Frisby Master
Level 3:
Answers
4384
Questions
5
Helped
1319730
Points
25577
5 Related Answers
Anonymous
  • 47 Answers
  • Posted on Mar 09, 2008
SOURCE: How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Anonymous
  • 3 Answers
  • Posted on Jul 12, 2008
SOURCE: technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
A
Anonymous
  • Posted on Aug 18, 2008
SOURCE: Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Anonymous
  • Posted on Oct 06, 2008
SOURCE: hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Anonymous
  • 4 Answers
  • Posted on Jan 28, 2009
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Frisby FS-5020BT 5.1 Surround Sound Home Theater. I need to lower the bass on my Frisby FS-5020BT?
See highlighted text. It has an Equaliser
Description
  • Bluetooth 2.1 and enhanced bass technology/compatible with all Bluetooth enabled devices.
  • USB/SD/MMC memory cards audio inputs.
  • Bluetooth wireless range: Approximately 30 ft..
  • LCD display (track you're playing or adjust EQ level or volume).
  • Imported from USA (Sizes & Specifications are based on the USA Market).
FrisbyFS-5020bt Bluetooth 5.1 Speakers provides clear sound from
all satellite speakers and woofer from up to 30 feet away. You
can sync any Bluetooth enabled device, your phone, tablet, media
player or even your computer. The subwoofer features an LCD
screen that makes it easy to see which track you're playing or
adjust EQ level or volume. Frisby fs-5020bt supports Bluetooth
5.1 Technology for streaming audio wireless from devices that are
Bluetooth-enabled. For other non-Bluetooth devices, there is a
3.5MM auxiliary input ports. Additional conveniences include an
LCD display and included remote control. You've got full power to
fill your room with big, balanced sound. Both speakers and the
subwoofer are magnetically shielded to provide the protection
against image distortion from external electronic sources.
Compatible with all pc models, laptops, smartphones and all mp3
players, iPod, Discmans, Walkman's equipped with headphone jack.
The included remote control has controls for bass and treble EQ, volume, play/pause, previous/next track, Bluetooth sync and
power. The speaker also has an LCD display and volume/sync
buttons.
Frisby FS-5010BT 5.1 Surround Sound Home Theater Speakers System with Bluetooth USB/SD and Remote reset bluetooth
You can't reset the Bluetooth device, you remove the connections from the devices connected to it, smartphone televisions etc. On the device click the Frisby and then click 'Forget Device'. To reset a remote, you just remove the batteries for a while.
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
Hi, our family is attempting to hook up and install a frisby 5.1 digital surround sound home theater system to our spectroniq pltv3250 32 lcd tv without success. As instructed, we are using all the correct...
Pl check all speaker connection is ok after that take AV out of your LCD Tv & connect with your home theater system for audio input in your home theater system
3helpful
2answers
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Top Frisby Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Don A
Don A
Are you a Frisby Audio Player and Recorder Expert? Answer questions, earn points and help others
