Cars & Trucks Logo
Darryl Nuske Posted on Jun 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing motors Will a 1998 vinE motor replace a 2004 vinE motor?My 2004 motor seized but l have a good 1998 motor.
Jeff Wilson
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 37 Answers
  • Posted on Jun 12, 2017
Jeff Wilson
Expert
Level 2:
New Friend:
Cheetah:
Answers
37
Questions
0
Helped
8567
Points
114
Yes It will work. The Explorer has used the same engine for years. The same engine is also found in the Bronco.
1helpful
Changing engines Ford Explorer 4l ohc.
Yes, same block setup, with most all attachments also. should be an easy pull and remove.
Back wipers and washer keeps fusing
This is caused by either a broken wire or, more likely, a seized motor. When the motor is seized it has to draw a lot more current to try and work, this will blow the fuse. Check the motor and wiper arm are free to move easily.
Too late for my daughter's 2004 Impreza wagon. The motor seized while driving on the freeway. Now the motor will need to be replaced or rebuilt. She was told by the mechanic that looked at it...
MOTOR SEIZED LACK OF OIL.SHE COULD HAD OIL LEAK. LOW OIL WARNING LIGHT BULB COULD HAVE NOT BEEN WORKING WHILE DRIVING DOWN THE ROAD ENGINE LOCKED UP.IF ENGINE OIL WONT LOW. TIMING BELT COULD HAVE BROKEN.
Installing a starter for a 1998 bonneville...Have replaced battery and starter but when starter engages gets jammed on fly wheel and doesnt turn. Shimmed and still doesnt turn
first check to see if motor will turn over put socket on bolt on crankshaft pulley if motor doesn't turn over u have a seized motor
if it does turn over than i remove tranny and check to make sure flywheel is bent or cracked
2answers
94 ford ranger standard trans removal all bolts off hot do you br
it could be seized on the locating dowls,also could be seized in the spigot shaft bearing ,try bouncing the gearbox up and down while prying at the same time
Anyone experiencing repeated broken rear wiper motor?
yes my reaR WIPER WNT WORK I HAVE TO REPLACE THE MOTOR
sorry about caps
00 grand am motor seized
If the motor is seized you'll have to either rebuild it or replace it. Sorry for the bad news. Good luck
Heating and blowers don;t work
The motor has probably seized and burnt out, not that expensive
Interior Fan Motor won't stop 2004 VW Touareg
Find and replace the Blower fan relay, not sure where it is on your VW but it's common to be in with the fuse box by the battery. Good luck and hope this helps. When the relay goes bad from the heat of the electrical current, it seizes and does not disengage keeping the connection causing the ran to keep running.
Changing a motor in 98 bonneville
The factory procedure is to remove from the top. You need to remove the inner fender to remove harmonic balancer. Tight quarters for this job. Some garages have told me that remove these from the bottom, preference I guess but I prefer the to use the factory procedure barring a time-saving shortcut.
What is wrong with the current engine? If it is seized get back to me.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
