I already got a whole tub full of water out by bailing the water out and soaking up the rest with towels. I don't see any more water. Is there a hidden water place? Thank you.
SOURCE: Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
SOURCE: fisher and paykel smart drive 503 top loading washing machine
while under the lid there should be a tech sheet, explaining varions flashing light codes and there respective fixes for each instance, replacing tha switch(out of bal switch) seems like a good start though. cant remember if jumping it out will help, might be looking for a break in the line rather than continuity through it
SOURCE: GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
