Question about American Standard Home
I have a 2013 American Standard jacuzzi tub. I push the button to activate the jets and get a humming noise but the jets don't work. Any ideas on how to fix?
Posted by Jason on
2 Related Answers
P Marsh
SOURCE: when I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Posted on Aug 19, 2012
lpfaff1
L Pfaff
  • 11573 Answers
SOURCE: My American standard Jacuzzi tub hums when the button is pushed, but the jets do not turn on
Trey, motor or pump is seized, have tech. take a look and repair.
Posted on Feb 27, 2016
Regarding a 30x60 indoor jetted tub (Jacuzzi). When I push the on/off button, the pump slows down but then a few minutes later starts again on its own when there is no water. Any idea what is going
IF that is the one I recall, the switch is not connected to the tub. When you press the button, it sends air pressure to the switch under the tub to activate it;. You need to check the tubing and the switch
Feb 22, 2013 | Jacuzzi Home
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
My american standard jet tub will not turn on. It is plugged in and power is going to it. I worked just fine and then it simply stopped. It does make a small clicking noise when button in tub is pushed to...
' /* * For text ads, append each ad to the string. */ for(i = 0; i ' + 'Ads by Google' + '' + google_ads[i].line1 + ''; url = '' + google_ads[i].visible_url + ''; info = makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
'; s += url + info; s += ''; } s += ''; } document.write(s); G_GGL_SKIP += google_ads.length; return; } var G_MAX_ADS_WL = 1; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+1147946396"; google_ad_output = 'js'; google_max_num_ads = '1'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Problem with the American Standard Bathtubs / Whirlpools By bassassist69 on Sep 02, 2011
Hello: Please contact us at Wmerican Standard Brands and we will gladly help you.
1-800-442-1902
Monday through Friday
8:00 A.M. to 7:30 P.M. EST
Technical Customer Service
8:00 A.M. to 6:00 P.M. EST
8:00 A.M. to 3:00 P.M. EST Saturday
-Paul, on behalf of ASB
Sep 02, 2011 | American Standard Home
My american standard jacuzzi tub doesnt work. It's plugged in, but the push button doesn't engage anything. It worked before I removed it to install ceramic tile around and under it.
check the air tubing coming off the back of the motor. that tubing should connect from the air switch on the motor to the bottom of the air button on the top of your tub.
if it is not connected then it will never turn on.
Feb 03, 2011 | American Standard Home
American standard jacuzzi tub will not work. motor hums but jets do not come on
is this a new install? if so you may need to adjust the air intake. Or if you have kids they may have messed with the settings. If the air is closed all the way off....no bubbles.
Oct 18, 2009 | American Standard Antiquity 2038.016.020...
My american standard jacuzzi tub is pluged in but jets won't turn on
check for power at plug in if power your vacume switch is probably out replace switch.
Apr 28, 2009 | American Standard 2771.002.021 Cadet 5' x...
Home Logo
80 people viewed this question
Top American Standard Home Experts
Mike
john h
Bill Johnson
Are you an American Standard Home Expert? Answer questions, earn points and help others
