Question about Hayward Pool & Spa
SOURCE: No green comes out in backwash
Alge will quit often go through filter so first you need to kill the alge by super chlornateing the pool. You can take a water sampel to your pool store and give them the size of your pool, they can test your water, for nothing in most cases and recomend what you will need for this. Then you can start cleaning the mess up as the dead alge will turn to dirt. This dirt will be very fine and may go through your filter also so a cup full of D.E. in your skimmer after backwashing will usually coat the top of your sand and catch much finer dust and dirt. Do this as you clean the pool and backwash 1-2 times daily till clean. Follow all directions given to you at store to kill the alge first, this is very importiant.
Posted on Aug 24, 2009
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Posted on Oct 12, 2012
SOURCE: My new Hayward Pool Sand Filter won't backwash.
Hey!
Mine was doing the same thing. I had the hoses switched up. I had the hose from the pump connected to the port marked RETURN (on the Hayward vari pump valve). Not good! I also had the return line hose (from pool) connected to the port marked pump. It happens! The problem is I tried EVERYTHING ELSE before I found my error. This includes a trip to Leslie's to buy a brand new multi port valve (good thing they have a return policy) AND changing out my relatively new sand in the filter AND taking apart the vertical tube and each individual flange at the bottom to clean them out. Please check your hoses FIRST if it won't backwash! By the way...I've been a pool owner for 17 years. I think my experience worked against me since I didn't recheck my work at setup.
NOTE:
It might SEEM like your filter is working because you get suction at the skimmer and water rushing thru the return line into the pool. It's not working if your lines are backwards like mine were! My water started turning green!
Posted on Jun 22, 2013
Jul 18, 2014 | Hayward SAND FILTER, PRO SERIES
Jul 13, 2014 | Hayward SAND FILTER, PRO SERIES
Sep 10, 2013 | Hayward Pro Series 18" Above Ground Pool...
Jul 18, 2013 | Hayward S166T Pool Filter System w1 HP...
May 02, 2012 | Hayward Pool & Spa
Aug 09, 2009 | Hayward Sand Filter System & Tank 21" 1...
Aug 02, 2009 | Hayward SAND FILTER, PRO SERIES
Jul 30, 2009 | Hayward Pro Series 18" Above Ground Pool...
Jul 05, 2009 | Hayward SAND FILTER, PRO SERIES
Feb 18, 2009 | Hayward Pro Series 18" Above Ground Pool...
75 people viewed this question
