SOURCE: poulan Super 1800 16" chainsaw .
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
SOURCE: I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
SOURCE: Poulan chain saw carb tune
starts with the choke then shuts down when you shut off the choke. what is the settings for the carb
SOURCE: carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
SOURCE: poulan chain saw will not stay running after i sta...
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
