Question about Stanley Camping, Backpacking & Hiking
Changing batteries on stanley 77 153 how do i access battery compartment
Posted by rodney black on
Dave Reilly
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
Product manual is found at http://www.otelo.fr/waroot/OTFR/fr_FR/attachments/notice_instruction/3859_NI_47201300.pdf. See page 4 of 28, titled "Power" on how to change battery on this device.
Posted on Jul 21, 2017
4 Related Answers
Anonymous
  • 540 Answers
SOURCE: changing batteries in remote control
ype in the brand name on the web page and type in the model # and what it is.
Posted on Dec 17, 2009
PNiss
  • 151 Answers
SOURCE: looking for battery compartment
Your battery compartment is more than likely located in the back of the unit underneath the mounting bracket. You need to remove the mounting bracket in order to gain access to the battery compartment.
You can find your manual here:
http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_29897ge1_29897ge1.html
But it doesn't have any reference to your battery compartment for your phone. That I could find anyway.
Posted on Feb 10, 2010
Anonymous
SOURCE: I need to change the
What sort of chain saw do you have that has a battery?
I have owned many chain saws and NEVER seen one that has a battery.
Posted on Mar 19, 2011
gerardrjj
Gerard Jeronowitz
  • 6 Answers
SOURCE: need to change the batteries
I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
3. Pull off the bottom plate
4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
7. Carefully desolder the 2 wire leads from the old battery pack
8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
Posted on Apr 03, 2014
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
I can't find a user manual for stanley 15 amp automatic battery charger BC1509 no matter where I look. Can you help??????
Go here for the Stanley BC1509 15 AMP Battery Charger Manual:
http://www.baccusglobal.com/stanley/bc1509.php
Jul 15, 2011 | Stanley Black & Decker Stanley Bc1509 15...
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have a Stanley garage door opener built in the early 90's. Does the key pad have a battery?
yes it has a battery the bottom of the case slides down and, there is a 9 volt battery compartment
Jul 27, 2010 | Stanley Garden
Looking for battery compartment
Feb 10, 2010 | GE 29897GE1 Corded Phone
How do you change the car battery?
In my 1985 corvette the battery is located under the hood, but you must remove the panel on the driver's side to gain access to the battery. Hope this helps
May 09, 2009 | 1985 Chevrolet Corvette
Camping, Backpacking & Hiking Logo
4,474 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Tom Chichester
Mr.Mike
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
