Question about Hayward Pool & Spa
SOURCE: 1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Posted on Feb 22, 2010
Testimonial: "Great. Thanks for the quick feedback. I look forward to saving a few $'s this year operating my pool. Cheers!"
SOURCE: Install a timer to control pool operation
Another option would be to get an electronic timer like the Intermatic P1353 that has 3 circuits on it that you could program to cut on and off at different times. For example, you could have one circuit that controls the pump and turns the pump on, then the second circuit would turn on the booster pump at a set time after the filter pump had come on and then the heater could be set to also run at a preset time after the pump circuit was activated. Since the pump, booster and heater are all 220, it's a straight forward hookup with everything in one timer box.
The lights, as stated before, would be on a separate circuit (110) and have its own timer or photosensitive eye set in line.
Posted on May 11, 2010
Testimonial: "I read the P1353ME manual and it has the capability of exactly what I'd like to do. Thanks. "
SOURCE: pool pump turns off after 1/2 hour or so but I can
Your pump is protected by a thermal device that shuts it off when over heated. Are you running 110 or 220? In my experience, your pump will run cooler on 220 ... consider coverting if appropriate.
Posted on Aug 29, 2010
SOURCE: hayward pool heater h series
It could be that your gas connection has a blockage that is preventing adequate fuel for from getting to the heater. If that is not the case, try consulting your owners manual for these pool heaters. There is an online copy at the link below.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
Aug 24, 2014 | Hayward Pool & Spa
Jul 11, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Jun 13, 2014 | Hayward Pool & Spa
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Feb 09, 2011 | Grundfos Comfort System Recirculator ...
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
Aug 28, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Jul 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
May 25, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Jan 11, 2009 | Hayward Pool Products Hayward Xstream...
