Hello Carol
The first thing to do is contact your Phone Service Provider and check that you have a text service in operation and that you have credits available. Also International texting needs authorization on most plans.
Quoting from link: "Start by going to "Contacts" and tap on the contact you want to block. Then, press the menu key at the top left of your Doro PhoneEasy 612. You will see a menu where you will select "Block Number" or "Add to Auto Reject List". The title may vary depending on the model you own."
Hi -- I had this problem a few months ago. I found that if I took the battery out, let the phone rest for a few minutes, then put the battery back in then rebooted the phone. I did this a couple of times then the problem mysteriously disappeared. I hope this helps
