Question about Samsung Refrigerators
My samsung refrigerator model RF266AEPN refrigerator compartment won t go above 50 degrees
Posted by Edward Lynch on
Andy
    Habit-Forming:
    New Friend:
  • 117 Answers
Why would you want your fridge to run above 50 degrees.If you need above 50 degree then you don't really need a fridge
Posted on Jun 10, 2017
Dan Apthorp
  • Samsung Master
  • 2,824 Answers
I think if you check fridges are made to run fifty or below. Ours runs at forty five degrees.
Posted on Jun 09, 2017
My samsung french door RF266AEPN shows 888 after power went out
Quoting from link below:
"Try resetting it by pressing the top left and right buttons on the display and holding them for 10+ seconds. Let me know the outcome."
http://forum.partsdr.com/showthread.php?1243-FIXED-Samsung-Refrigerator-code-88-88-89
My Samsung refrigerator rf266aepn has a display 88 88 where the top of the 8 on the 3rd 8 is flashing. What does this mean and is there any way to clear the code? Will not clear when shut the breake
Have you had a power surge lately, if so it may have damaged your control board. This is a starting point, I am not that familiar with that model. If that is true you may want to check with your homeowners insurance agent.
How do I keep my RF266AEPN refrigerator with twin cooling, from icing up on the right side. This is a problem that has frequently happened in the summertime , but now, it is happening in the fall. Thi
Did you check the door gasket see if it is gunked up or air is leaking on that side? Have you felt around the door see if cold air escape? If air is escape means you will get icing or frost.
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Samsung RF266AEPN BUZZING NOISE
Is it buzzing from the compressor?
Samsung RF266AEPN BUZZING NOISE and back Panel Iced
Sometimes they ice up because the defrost cycle does not work, check for a faulty fuse, in the circuit board.
4helpful
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Refrigerators Logo
Top Samsung Refrigerators Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
