Can you replace the drive coupler on a Cooks Blender model XB9218WA? Something was stuck on my blades and by not turning properly, it destroyed the coupler. The motor seems undamaged.
If you need a replacement motor coupler for your Ronson 8342 stick blender, there are a few options you can try:
Check with the manufacturer: Contact Ronson customer support and inquire about the availability of a replacement motor coupler for your specific model of stick blender. They may be able to provide you with a replacement part or direct you to a authorized distributor.
Check online retailers: Look for online retailers that sell parts for small appliances, such as Amazon or eBay. You may be able to find a replacement motor coupler for your Ronson stick blender.
Check with local appliance repair shops: Local appliance repair shops may carry the replacement parts you need or have the contacts to help you find them.
It's worth noting that finding replacement parts for old appliances can be difficult and that's why it's always better to check with the manufacturer first.
Also, you might want to have the model and serial number of your stick blender when reaching out to the manufacturer or other suppliers, as it will help them to identify the correct parts for your specific unit.
you are using your KitchenAid blender and it stops blending, you may think there is a problem with the motor in your machine. However, a common reason for the blades not rotating in the blender is a dirty or faulty coupler. The coupler is what connects your blender dispenser to the motor, and you can easily replace the coupler at any time by only using a screwdriver. Things You'll Need
Flat-blade screwdriver
Turn the blender dispenser clockwise and lift up to remove it. Set the blender dispenser aside.
Insert a flat-blade screwdriver between the black drive coupler and the frame of the blender on the top center portion of the blender.
Lift the screwdriver upward, and the coupler will start to bend out of place. Slightly turn the coupler and then lift up on the screwdriver again.
Continue to move the coupler slightly and lift the screwdriver until the coupler is completely removed.
5
Insert the new coupler over the blender's motor blade and then twist the coupler counter-clockwise until it is tightly fastened.
Service and Repair 1-800-233-9054 Repair Department 550 Business Center Drive Mt. Prospect,Illinois 60056 This is on the back of the manual, hope it is still correct.
