SOURCE: No communication with computer
Pachicat you were exactly right! I had mine connected upside down too! Thanks for the tip!
SOURCE: Magellan explorist 600 gps with windows xp
It is more than likely a defective USB cable. I am on my third cable. They don't stand up to the abuse.
SOURCE: NMEA communication does not work ( but file transfer is OK)
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program http://www.visualgps.net/VisualGPS/
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
SOURCE: replacement parts for Magellan eXplorist GPS
You need to be brave, but it is pretty simlple. Basically you are going to clean the rubber keypad and circuit board contacts. These contacts develop a film over time that needs to be removed. That is the main reason telephone and remote control keypads fail over time.
1. Remove the battery.
2. Remove 5 screws holding the bady together and separate the backplate from the main body.
3. Now carefully lift the circuit board out of the main body. Do not disconnect anything, but be careful with the rubber seal that fits between the back and front plates.
4. With the circuit board laying flat on your work surface, remove the rubber keypad. It is held in place over the joystick. Carefully lift it off the joystick and set it aside.
5. Use a clean pencil eraser and lightly rub the contacts on the circuit board. Do the same thing on the keypad by pushing the little knobs out where you can rub them. Blow away the dust.
6. Use a Q-tip with some alcohol to clean the contacts on the curcuit board and on the keypad.
7. When the alcohol is dry, put everything back together in the opposite order.
This should be good enough, but if it does not solve the issue, then buy a rubber keypad repair kit (an example is at http://www.mgchemicals.com/downloads/appguide/appguide0206.pdf) and try again.
Good luck.
SOURCE: GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
